Took the battery out and charged it with an external charger. The phone is alive again, and charging normal :D Strange that it didn't charged when it was in the phone.... |
1.. my device is in black screen now after restoring by using snowbreeze 2.7.3 , with 4.3.3 8j2 custom fw , 6.15 bd , it device is not showing any battery simbel when connected to itunes nor power on/off display , 2...i even tried with redsnow 9.rc16 itis worked by showing jailbreaking screen(an apple simbol), after it completed , same black screen , 3.... when connected to itunes it shows a popup box , itunes as dected and it is in recovery mode , u need to restore, so i m tried with 4.1 ,4.3.3 ,it process and dsplays error 3194 ... plz brother tell any solution ..... im waiting for your reply brother . |
this is old problem. disconnect battery for 5 minutes. failing that let phone sit not connected to anything for at least 1 day, 2 would be better. phone must have dead battery. than put in pwned dfu mode and restore. |
@AssComm I am having similar problem as you faced. Since you were able to solve it kindly guide me how to go about it. Here is the description of my problem, pl.. pl.. help: My iphone 3g (Aug 2008 manufactured) was becoming dead some time, but when I rang it from other phone it seems that bell was going but iphone was having blank screen. After some googling and pressing power/wake and home button for 10 secs solved the problem and it restarted. Now one night when it was having 70% charge and was working fine, the next morning when I pressed home button, nothing happened, just black screen. I again did power+home for 10 sec but again nothing. I put it on wall charge for 2-3 hours, still nothing. Attached to computer started itunes, but itune does not detect it. Finally I connected it to computer again pressed power+home for 10 sec, released power while holding home..... a relief sigh... as msg came "itunes has detected an iphone in recovery mode. You must restore....." I pressed shift+restore button and selected downloaded original ipsw file (4.2.1 which was there in iphone). Itunes shown msg "Preparing iphone to restore" and after 4-5 mins a message came "Iphone `iphone` could not be restored. An unknown error occured (1601)". I tried with custom ipsw which resulted in error 1600. I tried several times, even with different computer/laptop, changed the usb cable also but no result.. So I am still with dead iphone. Please help. Thanks in advance. Here is the log generated by itunes while restoring: 2011-11-06 10:07:49.561 [6140:a80]: restore library built Sep 14 2011 at 01:30:07 2011-11-06 10:07:49.561 [6140:a80]: iTunes: iTunes 10.5.0.142 2011-11-06 10:07:49.561 [6140:a80]: iTunes: Software payload version: 8C148 (option key) 2011-11-06 10:08:07.809 [6140:1c44]: iTunes: Specifying UOI boot image 2011-11-06 10:08:07.811 [6140:1c44]: AppleDevice::GetDeviceID: failed for iBoot 2011-11-06 10:08:07.811 [6140:1c44]: device software does not support nonce generation 2011-11-06 10:08:07.861 [6140:1c44]: requested restore behavior: Erase 2011-11-06 10:08:07.864 [6140:1c44]: *** UUID E6D8AE5E-28D2-F748-8E07-D301F7E3758D *** 2011-11-06 10:08:07.895 [6140:1c44]: amai: AMAuthInstallDebugWriteObject: debug object written: C:\Users\Kamal\AppData\Local\Temp\PerE61C.tmp\amai \debug\tss-request.plist 2011-11-06 10:08:09.450 [6140:1c44]: amai: tss_submit_job: HttpQueryInfo returned 200 2011-11-06 10:08:10.829 [6140:1c44]: amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.0.0) 2011-11-06 10:08:10.845 [6140:1c44]: amai: AMAuthInstallDebugWriteObject: debug object written: C:\Users\Kamal\AppData\Local\Temp\PerE61C.tmp\amai \debug\tss-response.plist 2011-11-06 10:08:10.976 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "KernelCache" has been previously personalized; skipping it 2011-11-06 10:08:11.011 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "DeviceTree" has been previously personalized; skipping it 2011-11-06 10:08:11.025 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "AppleLogo" has been previously personalized; skipping it 2011-11-06 10:08:11.346 [6140:2724]: AppleDevice::GetDeviceID: failed for iBoot 2011-11-06 10:08:11.346 [6140:2724]: device software does not support nonce generation 2011-11-06 10:08:11.346 [6140:2724]: <DFU Device 074A3230>: production fused device 2011-11-06 10:08:11.347 [6140:2724]: unable to open device_map.txt: No such file or directory 2011-11-06 10:08:11.348 [6140:2724]: AppleDevice::GetDeviceID: failed for iBoot 2011-11-06 10:08:11.348 [6140:2724]: device software does not support nonce generation 2011-11-06 10:08:11.349 [6140:2724]: WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964 2011-11-06 10:08:11.349 [6140:2724]: WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964 2011-11-06 10:08:11.354 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 1 2011-11-06 10:08:11.358 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 3 2011-11-06 10:08:11.362 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 5 2011-11-06 10:08:11.366 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 7 2011-11-06 10:08:11.372 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 9 2011-11-06 10:08:11.376 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 11 2011-11-06 10:08:11.381 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 13 2011-11-06 10:08:11.385 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 15 2011-11-06 10:08:11.389 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 17 2011-11-06 10:08:11.393 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 19 2011-11-06 10:08:11.397 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 21 2011-11-06 10:08:11.402 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 23 2011-11-06 10:08:11.407 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 25 2011-11-06 10:08:11.411 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 27 2011-11-06 10:08:11.416 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 29 2011-11-06 10:08:11.420 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 31 2011-11-06 10:08:11.424 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 33 2011-11-06 10:08:11.429 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 35 2011-11-06 10:08:11.433 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 37 2011-11-06 10:08:11.437 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 39 2011-11-06 10:08:11.441 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 41 2011-11-06 10:08:11.445 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 43 2011-11-06 10:08:11.449 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 44 2011-11-06 10:08:11.453 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 46 2011-11-06 10:08:11.457 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 48 2011-11-06 10:08:11.462 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 50 2011-11-06 10:08:11.466 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 52 2011-11-06 10:08:11.471 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 54 2011-11-06 10:08:11.476 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 56 2011-11-06 10:08:11.480 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 58 2011-11-06 10:08:11.485 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 60 2011-11-06 10:08:11.489 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 62 2011-11-06 10:08:11.493 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 64 2011-11-06 10:08:11.497 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 66 2011-11-06 10:08:11.501 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 68 2011-11-06 10:08:11.506 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 70 2011-11-06 10:08:11.511 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 72 2011-11-06 10:08:11.515 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 74 2011-11-06 10:08:11.519 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 76 2011-11-06 10:08:11.523 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 78 2011-11-06 10:08:11.527 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 80 2011-11-06 10:08:11.531 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 82 2011-11-06 10:08:11.535 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 84 2011-11-06 10:08:11.540 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 86 2011-11-06 10:08:11.544 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 87 2011-11-06 10:08:11.548 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 89 2011-11-06 10:08:11.553 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 91 2011-11-06 10:08:11.558 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 93 2011-11-06 10:08:11.563 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 95 2011-11-06 10:08:11.568 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 97 2011-11-06 10:08:11.572 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 99 2011-11-06 10:08:11.572 [6140:2724]: WinDFU::UploadData: EOF, cbRead: 296 2011-11-06 10:08:11.574 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 100 2011-11-06 10:08:11.574 [6140:2724]: WinDFU::UploadData: ZLP 2011-11-06 10:08:11.575 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6 2011-11-06 10:08:11.575 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC 2011-11-06 10:08:11.575 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7 2011-11-06 10:08:11.575 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000 2011-11-06 10:08:14.576 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8 2011-11-06 10:08:14.576 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET 2011-11-06 10:08:14.576 [6140:2724]: WinDFU::ResetDevice: resetting... 2011-11-06 10:08:14.593 [6140:2724]: WinDFU::FinalizeDfuUpdate: success 2011-11-06 10:08:14.593 [6140:2724]: <DFU Device 074A3230>: DFU succeeded 2011-11-06 10:08:14.648 [6140:1a5c]: WinAMRestore::OnInterfaceRemoval: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964 2011-11-06 10:08:14.651 [6140:1a5c]: WinAMRestore::ProcessDevNodesChanges: device: 0x07331b40, notify: 2, connected: 0 2011-11-06 10:08:14.651 [6140:1a5c]: WinAMRestore::ProcessDevNodesChanges: device: 0x07446b50, notify: 2, connected: 1 2011-11-06 10:08:14.652 [6140:1a5c]: AppleDevice::NotifyDisconnect: DFU \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964, inst: 0x7446b50 2011-11-06 10:08:14.685 [6140:a80]: _AMDFUModeDeviceFinalize: 074A3230 2011-11-06 10:12:14.864 [6140:a80]: iTunes: Restore error 1601 |
