Old 12-21-2009, 17:56   #16 (permalink)
Member: 206656
Took the battery out and charged it with an external charger.
The phone is alive again, and charging normal
Strange that it didn't charged when it was in the phone....
Old 07-14-2011, 14:28   #17 (permalink)
Member: 1585442
1.. my device is in black screen now after restoring by using snowbreeze 2.7.3 , with 4.3.3 8j2 custom fw , 6.15 bd , it device is not showing any battery simbel when connected to itunes nor power on/off display ,
2...i even tried with redsnow 9.rc16 itis worked by showing jailbreaking screen(an apple simbol), after it completed , same black screen ,
3.... when connected to itunes it shows a popup box , itunes as dected and it is in recovery mode , u need to restore, so i m tried with 4.1 ,4.3.3 ,it process and dsplays error 3194 ...
plz brother tell any solution ..... im waiting for your reply brother .
Old 07-14-2011, 22:49   #18 (permalink)
Member: 74075
Thanks Meter: 71
this is old problem. disconnect battery for 5 minutes. failing that let phone sit not connected to anything for at least 1 day, 2 would be better. phone must have dead battery. than put in pwned dfu mode and restore.
Old 11-07-2011, 12:54   #19 (permalink)
Member: 1685059
@AssComm
I am having similar problem as you faced. Since you were able to solve it kindly guide me how to go about it. Here is the description of my problem, pl.. pl.. help:
My iphone 3g (Aug 2008 manufactured) was becoming dead some time, but when I rang it from other phone it seems that bell was going but iphone was having blank screen. After some googling and pressing power/wake and home button for 10 secs solved the problem and it restarted.
Now one night when it was having 70% charge and was working fine, the next morning when I pressed home button, nothing happened, just black screen. I again did power+home for 10 sec but again nothing. I put it on wall charge for 2-3 hours, still nothing. Attached to computer started itunes, but itune does not detect it. Finally I connected it to computer again pressed power+home for 10 sec, released power while holding home..... a relief sigh... as msg came "itunes has detected an iphone in recovery mode. You must restore....."
I pressed shift+restore button and selected downloaded original ipsw file (4.2.1 which was there in iphone). Itunes shown msg "Preparing iphone to restore" and after 4-5 mins a message came "Iphone `iphone` could not be restored. An unknown error occured (1601)". I tried with custom ipsw which resulted in error 1600. I tried several times, even with different computer/laptop, changed the usb cable also but no result.. So I am still with dead iphone.
Please help. Thanks in advance.
Here is the log generated by itunes while restoring:
2011-11-06 10:07:49.561 [6140:a80]: restore library built Sep 14 2011 at 01:30:07
2011-11-06 10:07:49.561 [6140:a80]: iTunes: iTunes 10.5.0.142
2011-11-06 10:07:49.561 [6140:a80]: iTunes: Software payload version: 8C148 (option key)
2011-11-06 10:08:07.809 [6140:1c44]: iTunes: Specifying UOI boot image
2011-11-06 10:08:07.811 [6140:1c44]: AppleDevice::GetDeviceID: failed for iBoot
2011-11-06 10:08:07.811 [6140:1c44]: device software does not support nonce generation
2011-11-06 10:08:07.861 [6140:1c44]: requested restore behavior: Erase
2011-11-06 10:08:07.864 [6140:1c44]: *** UUID E6D8AE5E-28D2-F748-8E07-D301F7E3758D ***
2011-11-06 10:08:07.895 [6140:1c44]: amai: AMAuthInstallDebugWriteObject: debug object written: C:\Users\Kamal\AppData\Local\Temp\PerE61C.tmp\amai \debug\tss-request.plist
2011-11-06 10:08:09.450 [6140:1c44]: amai: tss_submit_job: HttpQueryInfo returned 200
2011-11-06 10:08:10.829 [6140:1c44]: amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.0.0)
2011-11-06 10:08:10.845 [6140:1c44]: amai: AMAuthInstallDebugWriteObject: debug object written: C:\Users\Kamal\AppData\Local\Temp\PerE61C.tmp\amai \debug\tss-response.plist
2011-11-06 10:08:10.976 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "KernelCache" has been previously personalized; skipping it
2011-11-06 10:08:11.011 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "DeviceTree" has been previously personalized; skipping it
2011-11-06 10:08:11.025 [6140:1c44]: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "AppleLogo" has been previously personalized; skipping it
2011-11-06 10:08:11.346 [6140:2724]: AppleDevice::GetDeviceID: failed for iBoot
2011-11-06 10:08:11.346 [6140:2724]: device software does not support nonce generation
2011-11-06 10:08:11.346 [6140:2724]: <DFU Device 074A3230>: production fused device
2011-11-06 10:08:11.347 [6140:2724]: unable to open device_map.txt: No such file or directory
2011-11-06 10:08:11.348 [6140:2724]: AppleDevice::GetDeviceID: failed for iBoot
2011-11-06 10:08:11.348 [6140:2724]: device software does not support nonce generation
2011-11-06 10:08:11.349 [6140:2724]: WinDFU::OpenDFUDevice: path: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964
2011-11-06 10:08:11.349 [6140:2724]: WinDFU::OpenDeviceByPath: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964
2011-11-06 10:08:11.354 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 1
2011-11-06 10:08:11.358 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 3
2011-11-06 10:08:11.362 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 5
2011-11-06 10:08:11.366 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 7
2011-11-06 10:08:11.372 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 9
2011-11-06 10:08:11.376 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 11
2011-11-06 10:08:11.381 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 13
2011-11-06 10:08:11.385 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 15
2011-11-06 10:08:11.389 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 17
2011-11-06 10:08:11.393 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 19
2011-11-06 10:08:11.397 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 21
2011-11-06 10:08:11.402 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 23
2011-11-06 10:08:11.407 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 25
2011-11-06 10:08:11.411 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 27
2011-11-06 10:08:11.416 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 29
2011-11-06 10:08:11.420 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 31
2011-11-06 10:08:11.424 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 33
2011-11-06 10:08:11.429 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 35
2011-11-06 10:08:11.433 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 37
2011-11-06 10:08:11.437 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 39
2011-11-06 10:08:11.441 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 41
2011-11-06 10:08:11.445 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 43
2011-11-06 10:08:11.449 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 44
2011-11-06 10:08:11.453 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 46
2011-11-06 10:08:11.457 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 48
2011-11-06 10:08:11.462 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 50
2011-11-06 10:08:11.466 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 52
2011-11-06 10:08:11.471 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 54
2011-11-06 10:08:11.476 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 56
2011-11-06 10:08:11.480 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 58
2011-11-06 10:08:11.485 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 60
2011-11-06 10:08:11.489 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 62
2011-11-06 10:08:11.493 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 64
2011-11-06 10:08:11.497 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 66
2011-11-06 10:08:11.501 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 68
2011-11-06 10:08:11.506 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 70
2011-11-06 10:08:11.511 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 72
2011-11-06 10:08:11.515 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 74
2011-11-06 10:08:11.519 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 76
2011-11-06 10:08:11.523 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 78
2011-11-06 10:08:11.527 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 80
2011-11-06 10:08:11.531 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 82
2011-11-06 10:08:11.535 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 84
2011-11-06 10:08:11.540 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 86
2011-11-06 10:08:11.544 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 87
2011-11-06 10:08:11.548 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 89
2011-11-06 10:08:11.553 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 91
2011-11-06 10:08:11.558 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 93
2011-11-06 10:08:11.563 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 95
2011-11-06 10:08:11.568 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 97
2011-11-06 10:08:11.572 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 99
2011-11-06 10:08:11.572 [6140:2724]: WinDFU::UploadData: EOF, cbRead: 296
2011-11-06 10:08:11.574 [6140:2724]: <DFU Device 074A3230>: operation 0 progress 100
2011-11-06 10:08:11.574 [6140:2724]: WinDFU::UploadData: ZLP
2011-11-06 10:08:11.575 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 6
2011-11-06 10:08:11.575 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_SYNC
2011-11-06 10:08:11.575 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 7
2011-11-06 10:08:11.575 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST, PollTimeout: 3000
2011-11-06 10:08:14.576 [6140:2724]: WinDFU::FinalizeDfuUpdate: GetStatus: status: 0, state: 8
2011-11-06 10:08:14.576 [6140:2724]: WinDFU::ProcessUpdateState: status.bState == DFU_STATE_MANIFEST_WAIT_RESET
2011-11-06 10:08:14.576 [6140:2724]: WinDFU::ResetDevice: resetting...
2011-11-06 10:08:14.593 [6140:2724]: WinDFU::FinalizeDfuUpdate: success
2011-11-06 10:08:14.593 [6140:2724]: <DFU Device 074A3230>: DFU succeeded
2011-11-06 10:08:14.648 [6140:1a5c]: WinAMRestore::OnInterfaceRemoval: \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964
2011-11-06 10:08:14.651 [6140:1a5c]: WinAMRestore::ProcessDevNodesChanges: device: 0x07331b40, notify: 2, connected: 0
2011-11-06 10:08:14.651 [6140:1a5c]: WinAMRestore::ProcessDevNodesChanges: device: 0x07446b50, notify: 2, connected: 1
2011-11-06 10:08:14.652 [6140:1a5c]: AppleDevice::NotifyDisconnect: DFU \\?\USB#VID_05AC&PID_1227#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\0000#8c9b7964, inst: 0x7446b50
2011-11-06 10:08:14.685 [6140:a80]: _AMDFUModeDeviceFinalize: 074A3230
2011-11-06 10:12:14.864 [6140:a80]: iTunes: Restore error 1601
Iphone 3Gs in DFU mode , how can exit dfu mode ? dieuphong2003 iPhone 2 / iPhone 3G / iPhone 3GS 37 06-23-2011 13:58
blackberry 8310 for att won't turn on ..black screen, only red led flashing lights shadigsm BlackBerry (RIM) 1 06-02-2010 12:56
hi all i got e65 black screen only not do any thng else ahmad yousif Nokia Hardware & Hardware Repair 5 02-25-2010 15:23
help my iphone in only dfu mode KHANGULMAMA iPhone 2 / iPhone 3G / iPhone 3GS 5 02-24-2010 05:42
n95 black screen only when slider is closed themanisback Nokia Hardware & Hardware Repair 8 01-07-2009 13:17
Page generated in 0.33041 seconds with 8 queries
