Old 12-06-2011, 12:57   #1 (permalink)
Member: 1176729
Thanks Meter: 8
3gs network after restore ?
this 3gs was having V5.0.1 and i downgraded to V4.1 .after installed baseband and ultrasn0w , it is working properly. when i insert every sim card it is showing his network. but the problem is when i try to call with sim i inserted,the call is disconnected.i can't make a call. each sim dooing as same. but there is network showing as well.
**only the original sim working properly.
what can i do to work other sim cards ?
pls help me.
Old 12-06-2011, 19:49   #2 (permalink)
Shahin Hasan's Avatar
Member: 1529244
Sonork: 1720
Thanks Meter: 150
Brother,
try this solution.
Unlock to iOS 5.0.1 with Ultrasn0w iPhone 4/3GS
The Following User Says Thank You to Shahin Hasan For This Useful Post:
Old 12-07-2011, 02:37   #3 (permalink)
Member: 240043
Thanks Meter: 77
Originally Posted by spider08 View Post
this 3gs was having v5.0.1 and i downgraded to v4.1 .after installed baseband and ultrasn0w , it is working properly. When i insert every sim card it is showing his network. But the problem is when i try to call with sim i inserted,the call is disconnected.i can't make a call. Each sim dooing as same. But there is network showing as well.
What can i do to work other sim cards ?
Pls help me.
update again baseband 06.15 with redsnow
The Following User Says Thank You to cesartefacto For This Useful Post:
Old 12-07-2011, 03:59   #4 (permalink)
Risan Fassy's Avatar
Member: 617198
Sonork: 100.1606436
Thanks Meter: 212
pls help me.
after restore to 4.1..
If you jailbreak with redsn0w_win_0.9.6b5 or with this redsn0w_win_0.9.6b6..
Then did you check settings---> Phone---> show my caller Id set to on?
Old 12-07-2011, 15:36   #5 (permalink)
Member: 1176729
Thanks Meter: 8
i tried everythink but no way. i reflashed 3 times ipas base band there iwas no result.
when i inserted any sim ,the phone show the network but when i try to call,it does't make a call.
**only original sim working perfectely.
pls any ther solutions ?
Old 12-08-2011, 09:56   #6 (permalink)
Member: 617198
Sonork: 100.1606436
Thanks Meter: 212
If the version is now 4.1..
please use to jailbreak redsn0w_win_0.9.6b5 or redsn0w_win_0.9.6b6..
Others will not work..
then check your base band is now 6.15?
Have done plenty..
Old 12-08-2011, 10:47   #7 (permalink)
Member: 972745
Sonork: 100.1627715
Thanks Meter: 214
Check The IMEI Is It BlackListed?
Disable 3g on the handset + reset network settings
6150 Network problem, please HELP! ZF Nokia Hardware & Hardware Repair 4 07-06-2004 18:07
5110/6110 after unlocking see only network to which it was locked and ... 2M Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 07-25-2000 00:51
5110 5.24 locked all 4 locks after unlocking... MCG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2000 21:24
HEX for CLIP to restore Factory Defaults X-Shadow Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2000 14:59
"Menu 11"? after Net monitor Pyron Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-09-1999 10:07
Page generated in 0.30216 seconds with 8 queries
