05-11-2011, 00:05 | #1 (permalink) |
Junior Member Join Date: May 2011
Member: 1573797 Status: Offline Thanks Meter: 0 | 3GS New Bootroom BB6.15 ALWAYS itunes error 1611, tried everything need solution pls Situation: A friend gave his iphone 3GS, new bootroom ipad BB 6.15 on firmware 4.3.2, jailbroken with redsn0w, stuck in recovery mode, to me. What he did: 3GS was jailbroken before on 4.2.1, also with redsn0w. not unlocked, offical carrier (vodafone germany). He updated it to offical firmware 4.3.2 (without cfw) and used redsn0w for jailbreak. all worked. working nearly a weak, the phone crashed itno recovery mode while the device was on, everything working pretty well. No SHSH files saved!!! I tried EVRYTHING to get out of recovery mode!!!! without restore 1.Using TinyUmbrella = not working 2.Using RecBoot = not working 3.Using Fixrecovery = not working with restore 1. TinyUmbrella, Advanced, Enable Set Hosts to Cydia.... 2. Remove Cydia's SHSH caching server from your hosts (C:\WINDOWS\system32\driver\etc\hosts) as administrator (I'm using Win7) 3. Restart my Computer 4. Putting into DFU Mode with iREB or redsn0w (tried both) 5. Restore with shift in itunes using cfw 4.3.2 and 4.3.3 (downloaded both, tried to create own cfw of both with snowbreeze = nothing worked) >> Always gives me Itunes error 1611 = Apple Logo, phone tries to reboot and immediatly goes back into recovery!!!! Using different USB Ports, uninstalled Itunes different times, all Apple applications + Bonjour etc.... removed itunes media libery......and installed it again, again and again.... What the hell I`m doing wrong??? Need solution please =( |
05-11-2011, 03:35 | #2 (permalink) | ||
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | Quote:
U need sn0wbreeze 2.7.1 ,3gs firmware 4.3.3, irebr-4, latest iTunes, The Host file should have # on all lines e.g Quote:
After that use ireb to make the phone enter DFU. Then you open iTunes and you flash the Phone using the CUSTOM firmware you created. Problem SOLVED. | ||
05-11-2011, 04:08 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: INDIA
Member: 511749 Status: Offline Thanks Meter: 335 | Its Write Solution My Friends [QUOTE=zakiyyboss;7301804]Follow me: U need sn0wbreeze 2.7.1 ,3gs firmware 4.3.3, irebr-4, latest iTunes, The Host file should have # on all lines e.g Now you make a custom firmware using sn0wbreeze and the ios 4.3.3. After that use ireb to make the phone enter DFU. Then you open iTunes and you flash the Phone using the CUSTOM firmware you created. Br. Lokesh |
05-11-2011, 04:18 | #5 (permalink) |
Crazy Poster Join Date: Nov 2007
Member: 639200 Status: Offline Thanks Meter: 10 | Make cfw 4.3.1 using snowbreeze 2.5 then open itunes and update using your cfw jailbreak using redsn0w_win_0.9.6rc11 with original firmware after jailbreak unlock with ultra snow fixer... |
05-11-2011, 11:16 | #9 (permalink) | |
Member: 1573797 Status: Offline Thanks Meter: 0 | Quote:
Created cfw 4.3.3 with all modes (simple, expert, basband.....) In my hosts file i got like four lines without "#". Opened as administrator, filled in the missing signs, saved it and restarted computer. I'm on the latest itunes version.Putting it into DFU with iREB-4 before restoring. Tried to flash iphone with CUSTOM firmware. >> ERROR 1611 You have any other ideas??? Is it possible to get out of this fu**ing recovery mode without smashing phone on the wall =) ?!!?! | |
05-11-2011, 11:40 | #10 (permalink) | |
05-11-2011, 12:43 | #11 (permalink) |
Freak Poster Join Date: Oct 2005 Age: 40
Member: 186734 Status: Offline Thanks Meter: 165 | If you still unsuccessful try this solution. Helped me last time 3GS unknow version, no shsh saved. 1. Remove line gs.apple.com x.x.x.x from hosts file and restart computer. 2. Restore to stock 4.3.3 firmware with latest iTunes. You will get error 16xx of course as you can not update the baseband. 3. Put phone in DFU mode and use latest redsn0w to jailbreak it. 4. If phone did not start after that use TinyUmbrella to exit recovery. If not working try to restore to custom fw v4.1, then do shsh backup and finally restore to 4.3.3 custom zeezoo |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
