08-30-2011, 15:49 | #31 (permalink) | |
Insane Poster Join Date: Jul 2005 Age: 50
Member: 161531 Status: Offline Thanks Meter: 9 | Fix for dfu loop fix. Quote:
Need softwares: 1. Tiny umberlla 2. Firmware 4.1 3. Firmware 4.3.3 4.redsn0w 9.6xxx 5 itunes step 1. Open ur tiny umberlla and start tss service step 2.. Open redsn0w and select 4.1 firmware and conncet ur phone with dfu loop phone,, then just tick juest enter pwned dfu mode.. And finish it... Now ur phone pwned dfu mode. Step3.. Now open itunes and restore with official 4.1 firmware.. Will flash ur phone and end with 1015 error.... And dfu mode again... Step 4... Very important one now close ur tiny umberlla step 5...open ur itunes now and restore with 4.3.3 official firmware (dont use pwned dfu now and dont use tiny umberlla.. This mistake lead us to dfu mood again)... Again ends with 1015 error and ur phone now diplay low battery symbol or recovery mode.. No problem...(if u have low battery symbol.. Wait to charge for sometime) step 5... Now use redsn0w with 4.3.3 and tick and jailbrake it... Struck while jailbraking ,,, now again repeat the same procedure now ur phone will be activated and work fine ... Now use ultrasnow to unlock from cydia... Now ur phone is unlocked and untechred .... Reply me ..... | |
The Following User Says Thank You to gavaskar66377 For This Useful Post: |
08-30-2011, 17:12 | #32 (permalink) |
Insane Poster Join Date: Sep 2007
Member: 581508 Status: Offline Thanks Meter: 5 | try this try another custom firmare, if not help, u have to remove the battery at least 2 hours, and then put it back ,,,post the results |
The Following User Says Thank You to chockwave For This Useful Post: |
08-30-2011, 18:59 | #33 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 66
Member: 74075 Status: Offline Thanks Meter: 71 | vasay , this is an old problem w/gs. if you can, disconnect mtherboard from battery and let sit for a few minutes. if you can not, disconnect phone from any charging source for at least 1 day, 2 would be better. phone must be dead. when you reconnect phone will still be in dfu mode. use redsn0w to put into pwned dfu mode, and then restore w 4.1 ipsw. phone should come up in restore mode. use ireb or tiny umbrella to kick out of restore mode. check host files and remove all apple references. good luck |
The Following User Says Thank You to jayh42 For This Useful Post: |
08-31-2011, 02:19 | #34 (permalink) | |
No Life Poster Join Date: Jan 2001 Location: France/Martinica/CPU Age: 45
Member: 3026 Status: Offline Sonork: 100.1602750 Thanks Meter: 102 | Quote:
No need to modify host file and use original firmware | |
The Following User Says Thank You to kham For This Useful Post: |
08-31-2011, 07:29 | #35 (permalink) | ||||
Junior Member Join Date: Aug 2011
Member: 1642646 Status: Offline Thanks Meter: 0 | Quote:
BTW I have removed the battery and left it for days already. I will try again but this time I will try with 4.1 firmware like you suggest | ||||
08-31-2011, 18:37 | #36 (permalink) |
Member: 1642646 Status: Offline Thanks Meter: 0 | gavaskar66377 On step two when i choose 4.1 it says unable to recognize IPSW. Its because i'm already on 4.3.3 right? Should I downgrade with itunes first and then start from step 1? |
09-02-2011, 05:45 | #37 (permalink) | |
09-02-2011, 11:02 | #38 (permalink) |
Junior Member Join Date: Sep 2008
Member: 852006 Status: Offline Sonork: 115693 Thanks Meter: 3 | Dfu mode To restore 3gs,if stuck on dfu mode i did one mobile use irib and tinyumbrell, 1st connect iphone start irib execute for 3gs,and now start tiny umbrella start tss ,then launch itunes restore iphone with 4.1 and it can give u error sodo this process again this time use custom firmware .1 hope ur will work mine i did |
The Following User Says Thank You to yashp71 For This Useful Post: |
09-03-2011, 21:08 | #40 (permalink) | |
09-03-2011, 22:24 | #41 (permalink) |
Member: 1642646 Status: Offline Thanks Meter: 0 | ok guys, some progress here. After getting stuck on step 4, I tried to update iphone using itunes, without pressing shift+restore. So it was restoring and then error 1015 came up and now i'm stuck with RECOVERY MODE. The itunes logo and cable. I think it's a good sign. What should I do? I dont want to mess it up again lol |
09-03-2011, 23:18 | #43 (permalink) |
Member: 1642646 Status: Offline Thanks Meter: 0 | I tried jailbreaking with redsnow using 4.3.3 but I'm not sure if its possible since I believe the phone is on new firmware. It keeps saying "please wait" then says some other crap really fast and turns off. when it turns back on it is still on recovery mode. Sorry if I'm spamming, just trying to fix this thing ASAP |
09-04-2011, 01:23 | #44 (permalink) |
Member: 1642646 Status: Offline Thanks Meter: 0 | Its me again. Here's what happened with second phone now. I'll go step by step of what I did. What I did to get to recovery mode from DFU loop 1. Opened tinyumbrella and clicked Start TSS Servers 2. Opened redsnow navigated to 4.1 and put my iphone into PWNED DFU mode using redsnow 3. After doing that Tried to restore with itunes using official 4.1 firmware, gave me errors 1600, 1618 4. Closed Itunes. 5. Opened ireb and clicked on "iphone 3gs", message popped "your device is now in PWNED DFU state (black screen" and left it at that, did not click on anything 6. Opened itunes and tried to restore. Again same error. 7. Closed Itunes. 8. With tinyumbrella running go to top left and you will see tag "Show all SHSHs" and click on that. There shouldn't be anything else showing there besides "Show all SHSHs" 9. After clicking on it (it will turn blue, meaning it is selected. helping total noobs out there) then go to the right corner and you will see button "Save all SHSHs", click on that. 10. Do not click on "Start TSS Server" 11. Open itunes 12. Shift+restore using official 4.3.3 13. Iphone will restore and give you 1015 error at the end. You can click "ok" or "x" or completely ignore it. Does not matter what you do at this point. 14. Your iphone should now be at recovery mode or battery charging logo This is what I did to get to recovery mode. I did not know what I was doing. I to this point do not know what happened but thats how I got BOTH of the phones from DFU to recovery mode. Hope this helps others. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
