Old 01-13-2016, 15:51   #1 (permalink)
Member: 2492889
Sonork: lymph47u5
Thanks Meter: 23
Iphone 4 IOS 7.1.2 BB 4.12.09 no service after successfully bypassing icloud Lost
Hello All,
I got an IPhone 4 IOS 7.1.2 BB 4.12.09 with ICloud lock and Lost status, I have successfully bypassed it and now the iPhone is working perfectly, but I Insert Sim Card to activate message. I inserted sim card but it can no service, I used Gevey card and still no service. keeping in mind that the phone was working on local networks without jealbreaking or doing any tweak to it.
is there other options that can be tried to overcome this Sim Activation?
The Following User Says Thank You to lymph47u5 For This Useful Post:
Old 01-13-2016, 15:53   #2 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
iPhone 4 bb 4.12.09 not work with Gevey. And if not activated with owner icloud not possible to use about normal phone. Only iPod
iPhone 5 using Tapatalk
The Following 2 Users Say Thank You to aircraft For This Useful Post:
Old 01-13-2016, 16:03   #3 (permalink)
Member: 2492889
Sonork: lymph47u5
Thanks Meter: 23
Thanks,
But is this problem associated only with 4.12.09 baseband? also is there a way to downgrade the baseband?
Old 01-13-2016, 16:22   #4 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
Not possible
The Following User Says Thank You to aircraft For This Useful Post:
Old 01-22-2016, 14:58   #5 (permalink)
virgin_phones's Avatar
Member: 359939
Sonork: none
Thanks Meter: 61
how did u disable the icloud. I need this solution badly.
Old 01-22-2016, 14:59   #6 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
Ssh rd winscp and jre x86
Old 01-24-2016, 23:29   #7 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
If the phone recognize SIM card before bypass , after bypass phone must works. but you have to put orginal baseband WildcardTicket back to phone, otherwise will not work.
Br.,
Denis
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Old 01-26-2016, 17:58   #8 (permalink)
Cheater -Don't Deal with him-
Member: 2353263
Sonork: +919836422676
Thanks Meter: 28
Activation bypass click here
Old 01-26-2016, 17:59   #9 (permalink)
Member: 2353263
Thanks Meter: 28
Originally Posted by lymph47u5 View Post
Hello All,
After bypass no service bcoz your phone is lost and stolen . After bypass your is just i pod
Old 01-28-2016, 18:47   #10 (permalink)
Member: 2515002
what method you have use for bypass? do you have delete setup app? that worng way if you do , give me ur skype here i will send your files for fix your bugs but if you have device unlock alerady not lock :-)
nesar786 Activation bypass click here.
this way delete setupapp is not good :-) worng worng...
Old 01-28-2016, 19:51   #11 (permalink)
aircraft's Avatar
Member: 1869762
Thanks Meter: 52
Type here solution dear. Share with all
Old 01-29-2016, 12:30   #12 (permalink)
Member: 2523436
Come ooon Please share the solution here with all .
Page generated in 0.20827 seconds with 8 queries
