Old 08-24-2015, 03:47   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
4s stuck on recovery error 9
4s stuck on recovery ..tried restore but in the end when waiting for iphone show apple logo with white line on iphone display, but failed to reboot with error 9 , sometimes error 4005 & 4013
alreay change charging ribbon,battery,cable,also try with other pc, try restore without lcd
but same
Old 08-24-2015, 10:14   #2 (permalink)
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,715
It is NAND Error. Most probably.
Sent from my 6+ using Tapatalk
The Following User Says Thank You to .::iRizwan::. For This Useful Post:
Old 08-25-2015, 12:18   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
but in google error 9 relate to usb issue
Old 08-25-2015, 16:48   #4 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,250
Try to write 9 beta version
Old 08-27-2015, 13:32   #5 (permalink)
Member: 2360250
Nand or baseband error, you can't do much besides replace that component.
Old 08-27-2015, 23:54   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
are u sure its a baseband or nand error ?
Old 08-28-2015, 09:51   #7 (permalink)
Member: 916323
Write 9 beta version
Old 09-01-2015, 20:23   #8 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i rehot wifi ic
remove q3i and make jumper
change battery
change charging dock
tried on different computers
when i restore the iphone 4s
after extracting the software and verifying etc, set will reboot and show apple logo with updating line
it take long time even an hour with no error
but when i disconnect manually it show an unlnown error 9
Old 09-01-2015, 20:36   #9 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Problem is in flash controller. Mild hot flash ic (sandisk) and try flash..should work
Sent from my SM-G800H using Tapatalk
Old 09-01-2015, 23:05   #10 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
will u please share with picture
Old 09-02-2015, 01:51   #11 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
one more thing this phone have issue in connecting
sometimes usb device not recognised
Old 09-02-2015, 02:27   #12 (permalink)
Member: 525940
Thanks Meter: 213
rehot nand ic then restore again
Old 09-02-2015, 02:49   #13 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
will u please locate the nand ic ?
Old 09-02-2015, 09:14   #14 (permalink)
invaderaze's Avatar
Member: 2091798
Sonork: 100.1662559
Thanks Meter: 156
Google for iphone 4s flash ic or nand memory..... See images
Old 09-09-2015, 06:01   #15 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
now only show error 4013
i try to restore without lcd /without housing
change dock / cable / battery but same error 4013
Page generated in 0.27509 seconds with 8 queries
