Old 07-15-2011, 09:22   #1 (permalink)
Member: 1333287
Thanks Meter: 11
Wink All mistakes iTunes with explanation
Errors -9815 or -9814 or -9800
Correct the date and time and restart the computer
Errors -50 or -35
Delete Storm Vedio, QuickTime iTunes,
And re-install iTunes
Errors 1, 6, or 1413 or 1417 or 1415 or 1418 or 1428 or 0xE8000065
Try to change the socket
usb
. Restart your computer
Error 2
Problem in installing Alcastm Frameur
Error 10
The file
LLB.
Missing in the original file Laframeur
Error 11
The file
bbfw.
Errors 13 or 37
Occur when you try to install Frameur beta on Windows only possible on the Mac system and try changing sockets
usb
Errors 14
Fail when trying to install Castm Frameur device is not to re-take-off or a problem in the socket Alliot SPIE
Errors 17
Failure occurs when the process of installing a private program Castm Frameur Snupreez
Errors 20
Searching correct fault.
Error 23
Errors 26
Fake copy of the file
NOR flash
In Laframeur
And also occur when you use an incompatible version of the program Alsnupreez
Errors 28
Hardware failure fatal crash happened on the memory module Achterab non-repair
Errors 29
Device is stuck in Alrikfra Maud tried to take him out of this situation
Errors 1002
Spoke about the attempt to install Kaastm Vrawir must make sure that your device
DFU MODE
Errors 1004
Failure occurs when the rise in private Albaspand Alristur in the process through the program
TINY UMBREALLA
Server and through Cydia
You can remove iPhone from case Alrikfra Maud when the pressure button.
EXIT RECOVERY
Of the program TINY UMBREALLA
Or updated version of the Green Poison that you are on 4.2.1 and Icon 4
Or 3GS
Errors 1013 or 1015 or 1602
Try the operation in a second computer or re-install Windows
Errors 1014
ITunes can not recognize the sockets in your Alaossbe
Errors 1600
Fail when trying to install Castm Frameur tried to put the device in Alrikfra Maud
Errors 1603
File Alkernal multiplied by the program used in the manufacture of Castm Frameur
Errors 1604
Errors 1611
ITunes fails to remove the device from Alrikfra Maud
Errors 1619
A very old copy of iTunes can not recognize the iPhone update your version of iTunes
Errors 1644
Break the connection when you try Alristur between iTunes and the file Laframeur promising attempt
Errors 2002 or 3XXX
ITunes can not connect to Apple Bserfr It's been used by another program
Or e Rmglq port 80 because of the program or skype or Almsinger Ante virus.
Errors 3002
Alristur Apple refused because of the file to your aid
SHSH
Them.
Errors 3004
Internet outage during the installation
Errors 3014
Failed attempt to modify the file hostmask
No Internet to contact Apple or server Bserfr Cydia
Errors 3194
The failure of the installation process because of the refusal to install Apple's latest version of Laframeur the only solution that you keep the file
SHSH
Contact Bserfr and Cydia
Errors 3195
Failed to connect to internet or not does not have the file
SHSH
Preserved
Errors 11222
Go to Settings and communication network and is the proxy server settings
Errors 0xE8000022
Searching ... ... ....
Errors 0xE800003D
Installation attempt failed because iTunes can not recognize on your local network.
Errors 0xE800006B
Was suddenly lost the connection between your computer and iPhone
Old 07-15-2011, 09:48   #2 (permalink)
Uvedovle's Avatar
Member: 10905
Thanks Meter: 109
Badly translated?
Cut and paste post?
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.22487 seconds with 9 queries
