05-28-2009, 14:14 | #16 (permalink) | |
Junior Member Join Date: May 2009
Member: 1040857 Status: Offline Thanks Meter: 2 | Quote:
for the users have the same problem (carrier null null) you dont have to use rebelsim,turbo sim etc to use your iphone after this.. here’s how i did it.. you need this requirements: itunes 8.1 firmware you want to upload to your iphone (2.2.1 / 2.2) quickpwn 2.2.5 Follow this method… - Start iTunes 8.1 for WINDOWS ONLY! i have no MAC so i dont know if this is possible with MAC users.. - Connect iPhone 3G via USB cable - Put the iphone into DFU mode (hold home + power for 10 seconds, continue holding home for 10 seconds) - At the restore screen in itunes “Shift-Click” Restore button, choose the firmware you want to install 2.2 or 2.2.1 - finish the entire processes, “Error 1013″, should pop-up, cancel it and immediately close itunes before it tries to connect to the itunes store! Note: if you got error message like 1011, 1013, 1015, just ignore them, its actually the firmware 2.2.1/2.2 is already successfully installed. But if you encountered with error message like 1601, 1602, 1600 or anything else then try putting the iPhone into DFU mode again and try again. these means you did not achieved the correct method on how to go to DFU mode - Open QuickPwn 2.2.5. it will say “must hold power and home for 15 SECS, then press power for 2 seconds” but hold the power button+home for 10 SECS ONLY then release the hone and power button then hold the power button for 2 second.. - Click OK and exit out of QuickPwn!(do not go thru quickpwn - no need!) - Your iphone will show a black emergency screen with itunes logo on it. (after you press the hold botton (2 Sec) - open itunes or wait for itself to open automatically.iTunes will take some time to recognize the device and connect to the apple store to unlock your iphone, “it will say your iphone has been unlocked congratulations.. - Your iphone will say “slide to unlock” do it, iTunes then prompts if you want to restore from a backup or it up as a new iPhone. Select new. - Now you can use quickpwn if you wish to jailbreak it! Just in case still no network after these steps: (waiting for activation after 10 mins minimum) 1. Follow all steps detailed in this guide. 2. Connect iPhone to iTunes. 3. Set up as new iPhone. 4. Wait for iPhone to say activating. 5. Slide iPhone to unlock. 6. Settings > General > Reset > Reset network settings. 7. Your iPhone will turn off and reboot. 8. You should have a message saying “iPhone is activated”. If still not, turn your iphone off, remove your sim and insert it again… then open… then repeat 2-8 steps above.. then you should activated it.. If again still not activated… Its time to jailbreak again the iphone… - Open Quickpwn 2.2.5 - run it - choose your firmware (2.2/2.2.1) - jailbreak it… After Jailbreak - open cydia look for yellowsn0w software (its 0 zero not o letter for snow) then look for carrier bundle software.. install it.. turn your iphone off, remove your sim and insert it again… then open… then repeat 2-8 steps above.. then it should have the network signal by that time… Hope guys this will help.. i did this all and my iphone now already have network again and using it without rebel to turbosim.. | |
The Following User Says Thank You to twotallanti For This Useful Post: |
05-28-2009, 18:13 | #19 (permalink) | |
No Life Poster Join Date: Nov 2002 Age: 43
Member: 17689 Status: Offline Sonork: 100.72392 Thanks Meter: 737 | Quote:
Can you please tell me who is the one in DELHI is doing unlock for 1000-RS? of cource for 5.9 and up bootloaders? | |
05-29-2009, 10:42 | #25 (permalink) |
Major Poster Join Date: May 2009
Member: 1038582 Status: Offline Thanks Meter: 4 | Let me try to sum up "twotallanti" post - just for my understanding: - Start iTunes 8.1 for WINDOWS ONLY! - Connect iPhone 3G via USB cable - Put the iphone into DFU mode - At the restore screen in itunes “Shift-Click” Restore button, choose the firmware you want to install 2.2 or 2.2.1 - finish the entire processes, “Error 1013″, should pop-up, cancel it and immediately close itunes before it tries to connect to the itunes store! - Open QuickPwn 2.2.5. it will say “must hold power and home for 15 SECS, then press power for 2 seconds” but hold the power button+home for 10 SECS ONLY then release the home and power button then hold the power button for 2 second.. - Click OK and exit out of QuickPwn!(do not go thru quickpwn - no need!) - Your iphone will show a black emergency screen with itunes logo on it. (after you press the hold (you mean home?) botton (2 Sec) - open itunes. iTunes will take some time to recognize the device and connect to the apple store to unlock your iphone, “it will say your iphone has been unlocked congratulations.. - Your iphone will say “slide to unlock” do it, iTunes then prompts if you want to restore from a backup or it up as a new iPhone. Select new. Now the iPhone should be unlocked e.g. using BB2.30.03 and BL5.9??? Can anyone confirm if this really works? Cheers, Tim |
05-30-2009, 05:34 | #29 (permalink) | |
Freak Poster Join Date: Mar 2006
Member: 251274 Status: Offline Thanks Meter: 23 | Quote:
yes i know dear thats you wasim ............. becoz i have sent some iphone to you and u have downgrade there modem with bootloader 5.9 and higher but you done it with hardware ......................... | |
05-30-2009, 08:16 | #30 (permalink) | |
I might had done for you but not for 1k if i have done unlock for 1000rs even a single handset out of 330 entries in my accounts computer i will give any services of VIRASAT ELECTRONIS for free for lifetime or else prove it with a bill or jobcard we issue to every customer with unique no. on it that we have done it for 1000rs or DO NOT SPOIL THE MARKET WITH BULL-CRAP PLEASE | |
any chance to downgrade bootloader 5.9 to 5.8? | AjeeB | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 05-01-2009 14:38 |
iPhone 3G Downgrade BootLoader 5.9 to 5.8 possible? | beezee_lao | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 04-27-2009 08:18 |
I need 3g 2.2.1 bootloader 5.9 solution | GNS_KUMAR73 | iPhone 2 / iPhone 3G / iPhone 3GS | 0 | 04-24-2009 11:39 |
""""solution about Bootloader 5.9 and 6.2"""" | oxygene31dz | iPhone 2 / iPhone 3G / iPhone 3GS | 5 | 04-22-2009 10:43 |
