Old 06-30-2012, 06:00   #1 (permalink)
mobilehelper's Avatar
Member: 1696653
Sonork: 100.1638410
Thanks Meter: 809
Apple-ipad-hard-reset
If something isn***8217;t working right, try restarting iPad, force quitting an application,
or resetting iPad.
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Force quit an application: Press and hold the Sleep/Wake button on top of iPad for a few seconds until a red slider appears, then press and hold the Home button until the application quits.
If you can***8217;t turn off iPad or if the problem continues, you may need to reset iPad.
This should be done only if turning iPad off and on doesn***8217;t resolve the problem.
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
iPad Still Doesn***8217;t Respond After Reset
Reset iPad settings. From the Home screen choose Settings *gt; General *gt; Reset *gt; Reset All Settings. All your preferences are reset, but your data and media aren***8217;t deleted.
resetting ipad
Reset all settings: Choose General *gt; Reset, then tap Reset All Settings.
All your preferences and settings are reset. Information, such as your contacts and calendars, and media, such as your songs and videos, aren***8217;t deleted.
Erase all content and settings: Choose General *gt; Reset, then tap ***8220;Erase All Content and Settings.***8221;
This resets all settings to their original values and erases all your information
and media.
Reset network settings: Choose General *gt; Reset, then tap Reset Network Settings.
When you reset network settings, your list of previously used networks and VPN settings not installed by a configuration profile are removed. Wi-Fi is turned off and then back on, disconnecting you from any network you***8217;re on. The Wi-Fi and ***8220;Ask to Join Networks***8221; settings remain turned on.
To remove VPN settings installed by a configuration profile, choose Settings *gt; General *gt; Profile, then select the profile and tap Remove.
Reset the keyboard dictionary: Choose General *gt; Reset, then tap Reset Keyboard Dictionary.
You add words to the keyboard dictionary by rejecting words iPad suggests as you type. Tap a word to reject the correction and add the word to the keyboard dictionary. Resetting the keyboard dictionary erases all words you***8217;ve added.
Reset the Home screen layout: Choose General *gt; Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General *gt; Reset, then tap Reset Location Warnings.
Location warnings are the requests made by applications (such as Maps) to use Location Services with those applications. iPad stops presenting the warning for an application the second time you tap OK. Tap Reset Location Warnings to resume the warnings.
The Following 2 Users Say Thank You to mobilehelper For This Useful Post:
Crash 'n' Burn java appl. WANTED! modrone x1x to x45/x50 2 04-21-2004 23:01
SL45 remote TV control java appl.!? modrone x1x to x45/x50 16 12-02-2003 00:40
where can I find bitween mobile fax full appl? codemonster Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-22-2003 16:08
how to delete camer appl from t722i gados Motorola P2k 2 07-18-2003 23:46
C/S35 appl. Probe1 x1x to x45/x50 0 09-05-2000 12:58
Page generated in 0.14915 seconds with 9 queries
