03-25-2013, 12:55 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Edinburgh, SCOTLAND
Member: 297431 Status: Offline Thanks Meter: 7 | Apple iphone 4s 3 Network Searching.... HELP!!!!!!!!!!! Customer bought in his iphone 4s To get the screen repaired after he droped it it has smashed screen , So Before changed the screen i Seen it had a signal it said 3 and had two bars then it went to no service so i asumed that because he was in the building, any way so I went ahead and changed the screen , everything went to plan , and the screen was working , so That was it all done , then the customer came back and said my iphone is just searching all the time, so i done reset network settings and turn wifi on and off and airaplane moad on and off but still the same , I have check if the phone is blacklisted on check mend and its not ......? So I need a solution I have had the iPhone check by a level 3 Mobile phone technician & He said there is no damage to the board ..... I asked the customer if this has happened before and he said yes the phone used to say invalid sim and he said he used to just take the sim in and out and it used to be ok .. So Please can some one help me ASAP .. Also we have tryed restore and downgrade and update to latest 6.1.3 Thank you Very Much . Auto 1 |
03-25-2013, 13:23 | #3 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Perth, Australia
Member: 93632 Status: Offline Thanks Meter: 8 | Quote:
befor you replace the lcd if you turn the unit off you can avoide this problem most times | |
03-25-2013, 16:57 | #4 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | problem is clock and date always connect itune |
03-25-2013, 22:47 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Nr Glasgow Age: 52
Member: 579376 Status: Offline Sonork: 100.1618321 Thanks Meter: 11 | this may sound silly, but check antenna cable at battery terminal. seems to be getting left disconnected all too often these days. |
03-26-2013, 11:41 | #8 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | com on guys... this is only will b solved to connect it to itune..... cz the fone is searching without sim card also..... and i have done so many fones... coz i am in hardware business every day i replace 2 or 3 lcd and with version 6.1 this problem comes in fone.. so just connect it to i tune do back up and rest the fone by pressing the power and home button together... |
