Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products)
iPhone ,iPod & iPad (Apple Inc. Products) iPhone 2G / 3G / 3GS / 4 / 4s / 5 , iPod , iPad / II / New, Apple TV and All Apple Inc. Products goes here
Old 11-26-2008, 08:38   #1 (permalink)
Member: 910073
Blank IMEI,Blank ICCID, Blank ModemFirware - Please help
There we go.Hopefully,I explain my situation clearly.
I got this iphone from one of my friend. He said he couldn't work it out and I thought I could (how foolish). So the problem is, there is no IMEI,no ICCID and no WIFI. And I keep of getting, the "Repair needed-cannot make or receive calls" message.Iphone was on 2.0.2 firware.
Following are "Solutions tried" and the "Result obtained"
Solutions tried 1:-
I tried to restore/downgrade to 1.1.4
Result obtained for 1:-
The restoring process got stuck at the message "Restoring firware". So, I just pulled the usb plug after 40min.Now I am stuck with "Itunes-usb arrow" logo.
Solutions tried:-
Whenever I try to restore/downgrade to any (I have tried 1.1.4,1.1.3,1.0.2) i either have one of the following things:-
-> Itunes get stuck at "Restoring Firmware". It takes ages with NO sucess
-> Sometimes, the restoring/downgrading process ends up quickly with an error message "20"
Solutions tried 3:-
I tried the process in
http://www.hackint0sh.org/forum/show...ghlight=anysim too but,
in Phase 1 Step 4, the App Installer gets stuck with message "Execute: iphonecomme.exe" and in cmd it gets stuck with message "entering recovery mode". So, I just pulled it and tried going further but to no success.
Solutions tried 4:-
Ended up with same problem when I tried this too :- http://www.hackint0sh.org/forum/showthread.php?t=13255
Solutions tried 5:-
Tried using winpwn
Result obtained for 5:-
Same as 1
Solutions tried 6:-
Tried using Kiphone
Result obtained for 6:-
Nothing changed
Some useful information for you guys about my situation
->I am using windows XP
->Itunes 7.5
->Iphone 4gb (helpful?)
->While using iLiberty when I ticked it to downgrade the bootloader from 4.6 to 3.9FakeBlank, it said somewhere that the bootloader version is 3.9_M3S2.
->Currently, I am in 1.1.4 firmware with no/very less SIGNAL, no IMEI, no ICCID no modem firware with no/low signal.
Please HELP ME!!! I have spend 3 days(NOT BULL****TING)and still can't find answer. Please help!!!
NOTE:- When helping,kindly give instructions by keeping in mind that the reader (i.e., me) know very less than you. So, please be very clear.No offence!
Old 11-26-2008, 21:04   #2 (permalink)
Member: 6642
Sell me the lcd screen sorry to say that but youll spend even more becouse you are in the magic circle and spining.
Try to switch it off if it restarts hold down a home button for 10 sec than if it stays turned off you are in the dfu mode try reflash it with original firmware when done do quickpawn and should work. But be patient it will take some time.
Old 11-26-2008, 22:39   #3 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
yeah i spent days on that phone &phone isn't Repaired yet seems like one of quickpwn release has sm REAL serious BUG to get the phone in that case
if u solved this problem let me know
Old 11-26-2008, 22:42   #4 (permalink)
Member: 910073
hi comiter.Have tried it.But didn't work. I tried to upgrade to 2.0 firware and then use quickpwn.But after upgrading (which as described got stuck at "Restoring Firmware" message), quickpwn seems to crash. So back to SQUARE ONE.
Any other ideas
FORGET IT.I wont and Cant sell you my iphone's lcd.
Thnks.
Old 11-26-2008, 23:09   #5 (permalink)
SLIPLOCK's Avatar
Member: 86301
@lostiniphone
Hi mate.
First you need to know what is your BL version and you can try to install and execute bootneuter.(post here the result if stuck on determinig setting)
But you need to know, sometime, corrupted bootloader cause blank imei and blank mac etc but the baseband is not real erased!
in this case, there is no solution until now, the only way is to change the com board. (if you can desolder sgold and flash a new bootloader by external prommer , it could be a solution but not testedstill now).
if your is ok you can try to restore fls and eep by geohot tools (use the one appropriate for your bootloader: ieraser for 3.9 ienew for 4.6)
Good luck
Old 11-27-2008, 00:38   #6 (permalink)
Member: 910073
Hi SLIPLOCK, please be bit more clearer. First of all how do I find what my bootloader version is?thnks.
Old 11-27-2008, 01:35   #7 (permalink)
SLIPLOCK's Avatar
Member: 86301
install bootneuter, if your bl is not corrupted, bootneuter will show you if you are in 3.9 or in 4.6.
for this, you need to make a custom image with winpwn, inside put installer, bsd subsystem,bootneuter,openssh,terminal...
Old 11-27-2008, 03:09   #8 (permalink)
Member: 910073
Hi SLIPLOCK,i hv installed bootneuter.It says version is 3.9, Neuter ON and Fake Blank OFF. Baseband Unlock ON. Now what do I do?thnks.
Old 11-27-2008, 10:18   #9 (permalink)
Member: 902533
man it seems like the most people are having thins problem.
this HAS TO BE THE END OF THE ROAD.
like the the UTLIMATE iphone ****-up
no solution or at least one that is updated.
RATS
Old 11-27-2008, 17:52   #10 (permalink)
SLIPLOCK's Avatar
Member: 86301
ok what happen if you choose flash in boot neuter?
Old 11-27-2008, 18:40   #11 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
boot Netuer can't do anything no known programmes for flashing bootloader can do anything with this situation seems like quickpwn give iphone Like FAke or not real bootloader so we get this problem
Old 11-27-2008, 18:59   #12 (permalink)
Member: 910073
Hey SLIPLOCK.after selecting Version 4.6 and flashing it, I ended up wif a messge saying "Bootloader successfully flashed to 4.6 but baseband was not (Error -516)" (something like this).Now what?
Old 11-27-2008, 19:36   #13 (permalink)
Member: 902533
flashing in bootneuter doesnt do anything to solve this problem
ive gotten that error before. u need to flash back to 3.9
Old 11-27-2008, 19:38   #14 (permalink)
Member: 902533
the funny thing, i have a IMEI, when i put in my sim card i have a ICCID and my modem firmware is correct
so wtf is wrong with my phone, no wifi or bluetooth
Old 11-27-2008, 19:49   #15 (permalink)
Moderator
~AhmedLeO~'s Avatar
Member: 224065
Sonork: 100.1577902
if u r on 1.1.4 try just try repair wifi using Ziphone or iliberty
Can i repair 3110c with imei 12345610654321 with MX KEY please help ntothel MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 10-10-2010 18:17
IMEI Change dont work Jack please help me ;-( Aydin007 SpiderMan 7 05-30-2008 06:46
6220 RH20 IMEI patching is not working! Please help! KUBAT1 MT-BOX 0 07-06-2006 10:45
3310 v4.24 no network, NFRE reads imei FFFF....6565....., Brobel/Viper please helps pyramid Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-20-2001 10:57
3310 v4.24 no network, NFRE reads imei FFFF....6565....., Brobel/Viper please helps pyramid Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 10-04-2001 15:29
Page generated in 0.58201 seconds with 12 queries
