Old 03-03-2009, 15:25   #1 (permalink)
Member: 985599
Call Failed Problem
Hello Folks, i got a annoying problem with my Iphone =/
I just bought my Iphone 3g 8gb a week ago, then i unlocked it with yellowsnow 0.9.8 and used a customized 2.2.1 firmware with baseband 2.28
Well, i can do everything with it, i can receive sms, send sms, receive calls but i can't make calls, when i tap CALL it say "Call Failed". I tried restore so many times, i tried change Sim but didn't work.
I heard that if i could turn off and on the option "Show my called ID" the problem could be fixed, but on my iphone i can't turn on or off because this option is freezed.
Anyone can help me?
Thanks
Old 03-03-2009, 15:37   #2 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Anyone can help me?
Thanks
Dawg, try this: Setting/Phone/Show Caller ID/ON it will work
Good luck
The Following User Says Thank You to nicacel For This Useful Post:
Old 03-03-2009, 15:39   #3 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Oh, I ok, try to turn on show caller ID ON with another sim card,
Old 03-03-2009, 15:40   #4 (permalink)
Member: 985599
Good luck
I can't, this option if freezed. =/
Old 03-03-2009, 15:45   #5 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Or do a reset all network
Old 03-03-2009, 16:55   #6 (permalink)
Member: 985599
I tried already, and i tried with another sim card too.
Any idea?
Old 03-03-2009, 17:00   #7 (permalink)
nicacel's Avatar
Member: 111014
Thanks Meter: 132
Does your carrier acept private number mode? Try to insert sim card with private option enabled then Turn On Show Caller ID, then insert your sim desire sim card. This is the only way I tried, in my country Movistar have private calling option, but with Claro is disable and this is what I did to fix this problem.
Old 03-03-2009, 17:16   #8 (permalink)
Member: 985599
Something is wrong, i was using other iphone before buy this one. I was using same SIM that i use today, it support private calling, but n this iphone this option is freezed.
Old 03-10-2009, 05:10   #9 (permalink)
Member: 985599
Ok i got news, don't know if is good or bad heh
Well when i go Settings > Phone > SIM Applications
then my carrier has a service to call to see how much credits i still have then i choose this option in SIM Applications, then appear a message "Your SIM would like to place a phone call" then it calls to *1113 to listen the credits, guess what? IT CALLS!! AND DON'T FAIL! So my phone can make calls!
But when i try by the normal way, it fail =/
Any ideas??
Old 04-13-2009, 16:05   #10 (permalink)
Member: 198717
Thanks Meter: 16
I have the same problem with an iPhone. Still no luck with fixing. I'm assuming it could be a baseband fault. Is there any way to delete the baseband back and flash it?
Old 04-14-2009, 10:28   #11 (permalink)
tcdxb's Avatar
Member: 314698
Thanks Meter: 47
i have the same problem too.. i can received calls and text but the problem when i try to call using this iphone using universal sim , i cannot make call it always call failed and the signal is dropping but after a while it returning signal again but the same cannot make call. i try all settings of universal sim but the same problem even i try rebel sim it the same..what is the problem?
UNIVERSAL SIM TEAM WHAT IS YOUR ANSWER ABOUT THIS PROBLEM?
Old 05-03-2009, 23:19   #12 (permalink)
Member: 237684
Thanks Meter: 60
anyyyy hellllllllllllllllllllllllllllllllllllllllllllllll lp
Old 03-18-2010, 23:23   #13 (permalink)
Member: 223770
Thanks Meter: 49
all iphone unlock methode
iClarified - Tutorials - iPhone
Old 03-16-2011, 05:25   #14 (permalink)
Member: 338008
Thanks Meter: 9
oki 100%
Old 03-16-2011, 05:27   #15 (permalink)
Member: 338008
Thanks Meter: 9
Good luck
my phone oki after do this it's work 100%
t100 full sgnal but not responding and call failed problem uqbah Samsung Hardware Repair 4 07-05-2006 22:39
R210 hang and have call fail problem MTi-GsM VLSI, Conexant, Skyworks and Old Models 2 05-23-2006 21:27
A800 Call Failed Problem!! MC Harami Samsung Hardware Repair 5 09-04-2004 01:47
R210S call failed problem pls help??? proxy_gsm VLSI, Conexant, Skyworks and Old Models 4 10-12-2003 00:14
My Samsung A300 Call Fail Problem Mahmudul Samsung Hardware Repair 6 09-27-2003 08:15
Page generated in 0.43663 seconds with 8 queries
