04-24-2016, 23:46 | #6 (permalink) |
Junior Member Join Date: Feb 2016
Member: 2531723 Status: Offline Thanks Meter: 0 | Hello Guys, I suddenly got problem Error 9 on my iphone 4S. I have been trying a lot of methods to recover my iphone with no luck. I would like to know if the jumper solution proposed in the picture above really works or not. Someone mentioned that it didn't work... I checked my iphone, and on the red area there is an Integrated Circuit (IC) that I do not know which function does. The solution points out to remove the existing IC and do the jumper proposed. Please I need your help to solve this issue... Is there any working solution? Thank you! |
06-08-2016, 06:42 | #8 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Nepal
Member: 622060 Status: Offline Thanks Meter: 37 | iphone 4s no audio after jumper on this ic hi thanx for ur solution but after applying this jumper my error 9 problem is solved but now no audio in video and volume button disappear . while calling audio is ok in both speaker and loudspeaker |
