08-05-2010, 13:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2009
Member: 1158839 Status: Offline Thanks Meter: 127 | cannot solve different sim dedected problem in 4.0.1 in iphone 3gs try every method?? iphone is 3gs 4.0.1? |
08-05-2010, 14:44 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Aug 2004 Location: MicroControllers:: Age: 43
Member: 78619 Status: Offline Thanks Meter: 297 | all u need to use above mentioned process.. if not sucesseded let me know i can over team viewer.. it must work.. all u have to cope lock down folder inside main lockdown folder from post .. |
08-05-2010, 14:52 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2003 Location: gsmcity Age: 44
Member: 21296 Status: Offline Thanks Meter: 328 | For the fist time I receive today 2 iPhones locked to O2 UK with the same problem. I flashed one of them even 2 times with iOS4.0.1 but again "Different SIM detected". It seems to me that when flashing with iTunes, it doesn't remove activation information so it just asks for the original SIM that activated for the first time that iPhone. But I solved the problem by browsing through iPhoneBrowser and deleting some folders conatined in /private/var/root/Library/ "Lockdown" folder and I leaved there just three files, and then rebooted the phone. "Different SIM detected" was gone You can also use WinSCP, but it is a little harder to work with so I use iPhoneBrowser for easier usage... So remove the three folders listed below "Lockdown" folder in the tree and leave just the three files that are on the photo on the right hand window Last edited by byteforce; 08-05-2010 at 15:01. |
The Following User Says Thank You to byteforce For This Useful Post: |
08-05-2010, 14:56 | #11 (permalink) |
Member: 78619 Status: Offline Thanks Meter: 297 | yes lock down folder with that just three files is only required to get rid of problem in library folder no matter how u access that folder via browser with cable or via terminal with winscp .. |
08-05-2010, 15:10 | #12 (permalink) |
Member: 1158839 Status: Offline Thanks Meter: 127 | my problem solved, download this file and try with same procedure RapidShare: 1-CLICK Web hosting - Easy Filehosting |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
