deleting setup.app need help i made a lot of times but now i have a problem when i run ssh_rd_rev04b.jar i got this that's okay Code: Code: login as: root |
its not problem with your phone it problem with your computer. windows what to expect! |
Sent from my GT-I8190N using Tapatalk |
Anybody ?? Programmers any idea this is first who happend to me |
there is no solution at the moment. what you have in your hand is the 8gb version of the iphone 4 which has new security that doesnt allow you to mount the partitions. i havent seen any solution yet |
in winscp cmd ( mount.sh ) |
Try copy the iPhone 7.0.4 ipsw to you C:\Users\YourUserName\AppData\Local\Temp\ssh_rd... Worked for me, after spending days trying. |
Still same problem FSŪ;10111540]Try copy the iPhone 7.0.4 ipsw to you C:\Users\YourUserName\AppData\Local\Temp\ssh_rd... Worked for me, after spending days trying.[/QUOTE] [QUOTE]SSH ramdisk maker & loader, version 29-06-2013 git rev-04b Made possible thanks to Camilo Rodrigues (@Allpluscomputer) Including xpwn source code by the Dev Team and planetbeing Including syringe source code by Chronic-Dev and posixninja syringe exploits by pod2g, geohot & posixninja Special thanks to iH8sn0w device-infos source: iphone-dataprotection Report bugs to msft.guy<[email protected]> (@msft_guy) Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\native\j syringeapi.dll Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\native\m ux_redux.dll Connect a device in DFU mode MobileDevice event: DfuConnect, 2341227, 8930 DFU device 'iPhone 4 (GSM)' connected Building ramdisk for device 'iPhone 4 (GSM)' Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\all_keys .plist Working dir set to C:\Users\Samiri\AppData\Local\Temp\ssh_rd IPSW at http://appldnld.apple.com/iOS5.1.1/0...8_Restore.ipsw Downloading Restore.plist Local file C:\Users\Samiri\AppData\Local\Temp\ssh_rd\iPhone3, 1_5.1.1_9B208_Restore.ipsw not found; downloading from http://appldnld.apple.com/iOS5.1.1/0...8_Restore.ipsw Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Restore.plist Restore.plist downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Restore.plist Parsing Restore.plist.. Kernel file: kernelcache.release.n90 Restore ramdisk file: 038-5512-003.dmg Downloading Firmware/dfu/iBSS.n90ap.RELEASE.dfu Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBSS.n90ap.RELEASE.dfu.or ig Decrypted to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBSS.n90ap.RELEASE.dfu.de c Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\nor5.pat ch.json Patched to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBSS.n90ap.RELEASE.dfu.de c.p iBSS prepared at C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBSS.n90ap.RELEASE.dfu Downloading Firmware/dfu/iBEC.n90ap.RELEASE.dfu Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBEC.n90ap.RELEASE.dfu.or ig Decrypted to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBEC.n90ap.RELEASE.dfu.de c Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\nor5.pat ch.json Patched to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBEC.n90ap.RELEASE.dfu.de c.p iBEC prepared at C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\dfu\iBEC.n90ap.RELEASE.dfu Downloading Firmware/all_flash/all_flash.n90ap.production/DeviceTree.n90ap.img3 Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\all_flash\all_flash.n90ap.pro duction\DeviceTree.n90ap.img3 Device tree prepared at C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\all_flash\all_flash.n90ap.pro duction\DeviceTree.n90ap.img3 Downloading Firmware/all_flash/all_flash.n90ap.production/manifest Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\Firmware\all_flash\all_flash.n90ap.pro duction\manifest Downloading kernelcache.release.n90 Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\kernelcache.release.n90.orig Decrypted to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\kernelcache.release.n90.dec Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\kernel5. patch.json Patched to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\kernelcache.release.n90.dec.p Kernel prepared at C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\kernelcache.release.n90 Downloading 038-5512-003.dmg Downloaded to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\038-5512-003.dmg.orig Decrypted to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\038-5512-003.dmg.dec Extracted resource to C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ssh.tar Added ssh.tar to the ramdisk Ramdisk prepared at C:\Users\Samiri\AppData\Local\Temp\ssh_rd\ipsw_iph one31_9B208\038-5512-003.dmg Using syringe to exploit the bootrom.. Exploit sent! Preparing to load the ramdisk.. Ramdisk load started! MobileDevice event: DfuDisconnect, 2341227, 8930 MobileDevice event: DfuConnect, 5291227, 8930 DFU device 'iPhone 4 (GSM)' connected Ignoring same device iPhone 4 (GSM) MobileDevice event: DfuDisconnect, 5291227, 8930 MobileDevice event: RecoveryConnect, 5291281, 8930 MobileDevice event: RecoveryDisconnect, 5291281, 8930 Almost there.. MobileDevice event: MuxConnect, 0, 0 Success! Connect to localhost on port 2022 with your favorite SSH client! login: root password: alpine Still SAme problem |
you need help dont you well i cannot now bye sa g |
Thanks all i solved this problem Alone dude's i Will Post Solotion Later Cause I'm working now |
you bettr post issue glad to help if you need anything else it will cost money. so there. sag |
how did you fix it ? |
Peace and Regards! |
