Old 10-10-2010, 18:09   #1 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
different sim detected after limerain
different sim detected after jailbreak by limerain
it is different frim the privious jailbreak only add limerain app so that we cant view raw system files can any one have good idea?
Old 10-10-2010, 18:17   #2 (permalink)
Member: 1410052
Thanks Meter: 3
Try this, May be it will solve different sim problem!
Reinsert your Phonebook SIM card (or dits sim card) to come out of emergency mode (Different SIM Detected)
2. If you already have Cydia, run Cydia from springboard then you have to go to Manage >> Source section, click Add button and add the following URL repo sources
Cydia.pushfix.info
3. After URL repo added, you have to search "Hacktivation"
4.. After found, Install Hactivation Patch from search results then confirm and wait until process finished.
The Following User Says Thank You to ali.arsd For This Useful Post:
Old 10-10-2010, 18:19   #3 (permalink)
Member: 904252
Thanks Meter: 5
solution is TCG tested 100% by Iphone 3g 3gs
1.-enter cydia - sources - edit - add
2.- tipear Cydia.pushfix.info
3.- enter in that repositori digited
you will find the pushfix hacktivation
instaled the lockdown ok
Old 10-10-2010, 18:27   #4 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
i try it but not working
Old 10-10-2010, 19:28   #5 (permalink)
Member: 625817
Sonork: 1592120
Thanks Meter: 32
use this way may be help you
1- use any iPhoneBrowser
2- go to /private/var/root/Library/ and delete orginal lockdown folder and put attached lockdown folder
3- restart phone
Old 10-10-2010, 19:35   #6 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
3- restart phone
here is the solution bro
http://forum.gsmhosting.com/vbb/f456...8/#post6431968
Old 10-10-2010, 19:40   #7 (permalink)
Member: 625817
Sonork: 1592120
Thanks Meter: 32
thanks bro many thanks
Old 10-10-2010, 19:44   #8 (permalink)
Member: 745985
not post any crap or whatever you think would solve the problem
probably read the post then comentzi
the iphone4 version 4.1, 02/10/2004 modem still does not work with what you publish
Old 10-10-2010, 20:08   #9 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
to fix that problem install afc2 first bro
or contact me by yahoo messenger
Old 10-10-2010, 20:09   #10 (permalink)
Member: 476075
Sonork: na
Thanks Meter: 40
cydia.pushfix.info does not work on 4g.
Old 10-10-2010, 20:14   #11 (permalink)
Member: 455794
Sonork: 100.1591235
Thanks Meter: 61
the only thing here is to install afc2 first so that u can get ur deep into the system
if it is not working on that use any browser & change lock down folder
i told u before u do this to got the lockdown folder on iphone browser or ifun box
Old 10-10-2010, 20:22   #12 (permalink)
Member: 745985
Continue to talk anything
FreeImageHosting.net Hosting Service
Old 10-10-2010, 20:28   #13 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 561
this solution dont work with 4.1 try and see
The Following User Says Thank You to algerienbox For This Useful Post:
Old 10-16-2010, 08:34   #14 (permalink)
Member: 1419372
3- restart phone
this is work to mine , thanks syrmic
Old 10-16-2010, 08:44   #15 (permalink)
Member: 1370484
Thanks Meter: 57
3- restart phone
Will this procedure will work for iphone 2G as well? because I have one and most I see is for iphone 3G & 3Gs posting only
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Page generated in 0.20599 seconds with 10 queries
