Old 04-19-2011, 18:49   #1 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
Thanks Meter: 417
Jailbreak iOS 4.3.2 Untethered On Windows Using Sn0wbreeze 2.6 [Tutorial]
iPhone developer iH8sn0w has just released Sn0wbreeze 2.6 for Windows users to fully jailbreak iOS 4.3.2 untethered running on iPhone 4, 3GS, iPad (1st-gen) and iPod touch. Just like Redsn0w, iPad 2 jailbreak on 4.3.2 is not supported yet.
Why use Sn0wbreeze over Redsn0w? If your iPhone relies on a carrier unlock, you must use Sn0wbreeze 2.6 which will help retain the old baseband for iPhone 4 and 3GS users so that they can be unlocked using Ultrasn0w. Complete step by step instructions for jailbreaking using Redsn0w on both Windows and Mac can be found here.
iOS 4.3.2 was originally jailbroken last week using PwnageTool bundles (on Mac) but it was limited to tethered boot. But now with the new version of Redsn0w and Sn0wbreeze, you can jailbreak your iPhone, iPad, and iPod touch fully untethered on the latest iOS 4.3.2 firmware.
Step 1: First, download all the required tools and files to your Windows desktop:
  • Download and install iTunes 10.2.2 for Windows.
  • Download Sn0wbreeze 2.6 for Windows.
  • Download iOS 4.3.2 for iPhone, iPad or iPod touch.
Step 2: Start Sn0wbreeze, click the next “blue” colored arrow to proceed.
Step 3: Select the required firmware .ipsw file for your iOS device by clicking on the “Browse” button.
Step 4: Sn0wbreeze will now identify the selected IPSW file. Once done, click the next “blue” colored arrow to proceed.
Step 5: Now select the “Expert Mode”, followed by “Build IPSW” option to start creating your custom firmware.
Since building custom firmware may take some time, you can optionally play Pac-Man game to kill some time.
Step 6: Sn0wbreeze will greet you with the following “Done!” message when the custom firmware has been successfully created.
Step 7: Now follow the onscreen steps to enter DFU mode using Sn0wbreeze:
  • Hold Power and Home buttons for 10 seconds
  • Now release the Power button but continue holding the Home button for 10 more seconds
  • You device should now be in DFU mode
If you have followed the steps correctly, you will get the following message from Snw0breeze
Step 8: Start iTunes, click on your iOS device icon from the sidebar in iTunes. Now press and hold Left “Shift” button on the keyboard and then click on “Restore” (Not “Update” or “Check for Update”) button in iTunes and then release this button.
This will make iTunes prompt you to select the location for your custom firmware 4.3.2 file. Select the required custom .ipsw file that you created above, and click on “Open”.
Step 9: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps. Be patient at this stage and don’t do anything silly. Just wait while iTunes installs the new firmware 4.3.2 on your iOS device. Your iOS device screen at this point will be showing a progress bar indicating installation progress. After the installation is done, your iOS device will be jailbroken on iOS 4.3.2.
sn0wbreeze 2.6
A Custom IPSW Creator for 4.3.2
Hotfile.com: One click file hosting: sn0wbreeze-v2.6.zip
More..
Old 04-19-2011, 20:11   #2 (permalink)
J@zz's Avatar
Member: 43032
Sonork: 100.1619349
Thanks Meter: 417
Note: In above post Images have been removed and i cant edit post now, so I am again posting it here. Sorry....
[IMG]http://2.bp.********.com/-xxCdJVNYG5Y/TZ1f6x9XX4I/AAAAAAAABGc/uIMdEgqr-ac/s1600/sn0wbreeze.jpg[/IMG]
Here’s how to jailbreak iOS 4.3.2 using sn0wbreeze v2.6:
Thing you will need during this process:
Step 1: Download and extract Sn0wbreeze-v2.6.zip preferably on your desktop (Windows Vista or Windows7 users must start the application in Administrator mode. To do so, right click mouse button on the icon and selecting “Run as administrator”
Step 2: Connect your iPhone or iPod Touch to your PC via USB.
Step 3: Click “Browse” button and select iOS 4.3.2 firmware which you downloaded earlier, you can also drag and drop .IPSW file on the given area.
Step 4: Sn0wbreeze will automatically verify the .ipsw file and the device which is required to be jailbroken. Sn0wbreeze will check the firmware if it is correct. Once the 4.3.2 IPSW is verified, click the blue arrow button to continue.
Step 5: Sn0wbreeze will give you option to select either “Simple Mode”, “Expert Mode” or “Baseband Preservation Mode” . Select ‘Expert Mode’ which will allow you to add multi-touch gestures on your device.
Or you can just go for simple mode if you don’t want to enable multi touch gestures.
Step 6 :
If you have an iPhone 4 (factory unlocked) or you are on an officially supported carrier like AT&T, DO NOT select “Activate the iPhone”. Make sure the option is unchecked. But if you rely on unlock make sure to check that option.
Step 7:
Click ‘Build IPSW’. Since building custom firmware may take some time, you can optionally play Pac-Man game to kill some time.
Step 8:
After completion press ‘OK’ button to follow the onscreen instructions to put your device into restorable state.
Step 9:
You will then be prompted to connect your device and click start when you are ready. Please turn off your iPhone 4 or any other iOS device. Put the device in DFU mode. Follow on-screen instructions.
To enter DFU mode:
Restore iOS 4.3.2 Custom Firmware Using iTunes
Step 10: Start iTunes, click on your iOS device icon from the sidebar in iTunes. Now press and hold Left “Shift” button on the keyboard and then click on “Restore” (Not “Update” or “Check for Update”) button in iTunes and then release this button.
Select the pre-jailbroken custom IPSW that was created (must be on your desktop) and click the Choose button.
Now relax and wait iTunes will do the rest for you. iPhone will restart on completion of firmware installation.
The Following 4 Users Say Thank You to J@zz For This Useful Post:
Old 04-21-2011, 19:16   #3 (permalink)
Member: 330888
Thanks Meter: 3
Great stuff
I find it here Here
It help me alot.
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-27-2022 22:12
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Page generated in 0.17365 seconds with 9 queries
