error 1, baseband chip replaced now new problem I have an iphone stoping update/restore with error 1 problem. So I reball baseband chip and now i can update/restore iphone. But now itunes says, There is a problem go to apple bla bla. Phone is stuck after chosing language in recover ymode I get no error, no heat, no visible damaged parts. Cydia shows me serial. What is the problem my friends ? |
just try to restore/update ? if it wont work, then you need to go to hardware forums.. |
Restore successful.I posted in hardware section. |
did you changed baseband chip or just reball/use same one again? because if you replaced, than you have one imei and different serial, so in apples database they dont match each other. that's why you are getting an error.. there is some ways to flash something on those chips to work again, will look for solution later... ir you changed it.. |
Same chip but I ripped some pads out from bb flash so destroyed it... to bad now |
