05-22-2011, 19:55 | #1 (permalink) |
Junior Member Join Date: May 2009 Location: Italy
Member: 1030071 Status: Offline Thanks Meter: 1 | Error 1600, 3194 and 21 iPhone 3Gs, Help !!!!! "The phone is always in DFU and I can not put in arrangements to recover!" Well I explain the problem I got with the touchscreen broke after a fall in the balcony, and the display is not seen nothing is all black, but the previous owner complies with the phone worked, but now when I try to restore I get the error 1600 and when I use the iREB to resolve the issue come to me the error 21, but also sometimes leaves the error 3194. As the display is black I think the problem 6R8 or IC 109 I tried changing the hosts file but nothing changes. Meets the http://forum.gsmhosting.com/vbb/f631...-21-a-1074050/ post, I think the only solution would be to change the picture replance: ImageShack® - Online Photo and Video Hosting mentioned in this post. I am trying to restore the sn0wbreeze, then the phone is sim locked, I also tried to restore the original file ISPW apple, but I could not fix. If someone could give ideas to respect, I would like very much. Thanks in advance Felix Last edited by dasilvafelix; 05-22-2011 at 20:00. |
05-23-2011, 22:37 | #4 (permalink) |
Member: 1030071 Status: Offline Thanks Meter: 1 | Surely SHSH not saved, then the jailbreak has not been done. You're right, now I've seen when I try to restore the last firmaware 4.3.3 does not happen the error 3194 and not 21. I am only the error 1600, even using iREB. I think I discovered the problem, the phone is blocked in DFU, I tried all the way to put out of DFU or Recovery Mode, nothing happens. When the phone fell and broke his toouch the display, a blacklight is not working now is all black, but I noticed when I tried to use another firmware prior to 4.3.3 error 3194 I went out and the display remained all white . Second I want to open another discussion to see how it comes out of the block of DFU, then I think it is hardware problem. Thanks Felix |
05-24-2011, 09:20 | #7 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: India
Member: 851193 Status: Offline Sonork: 100.1615313 Thanks Meter: 348 | Quote:
05-24-2011, 18:46 | #8 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1448240 Status: Offline Thanks Meter: 6 | the error 3194 is due to the downgrade code. gs.apple code. u will need to remove it. which from window is by the notes and if from OSX (Mac) is by the host. and then i will resolve the issue. For the 1600 may be the same issue as above may solve it or u need to use the iReb on sn0wbreeze to solve it. |
05-25-2011, 00:00 | #9 (permalink) |
Member: 1030071 Status: Offline Thanks Meter: 1 | Thanks for the reply, well the problem is that I can not put in recovery mode in any way reta only in DFU. Well as the 3194 error I get when I try to put the firmware prior to 4.3.3. I am using fw 4.3.3 sn0wbreeze to restore and I am always the error 1600, and when I try to use the iREB the display lights up and then remains fixed with the all-white screen and comes out the error 21. I tried to restore extinct with the original fw of Appeal and Error 21. At this point I think it is problem for replacement of the component conforms post: http://forum.gsmhosting.com/vbb/f631...-21-a-1074050/ Exists a ways to put the phone in Recovery Mode? How do I know if the problem is software or hardware? Apropos I have not received any invitation for Skype Thanks Felix |
05-25-2011, 05:33 | #12 (permalink) | |
Freak Poster Join Date: Jul 2006 Location: India(Sikkim)
Member: 311436 Status: Offline Thanks Meter: 38 | Quote:
Check this post | |
12-04-2011, 04:39 | #14 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Lithuania Age: 34
Member: 1593210 Status: Offline Thanks Meter: 1 | me iPhone 3G 4.1 iOS has same problem, it's stuck on recovery mode, In my case I already has 4.1 and 4.2.1 SHSH saved, There is what I do on Tinyumbrella TSS server mode using DFU and Recovery modes: tried restore to 4.2.1 - error 21 tried restore to 4.1- error 21 tried restore to 4.0 - error 21 tried restore to 3.1.3 - error 21 Used snowbreeze with 4.2.1 - error 21 Used snowbreeze with 4.1 - error 21 Used snowbreeze with 3.1.3 - error 1600 Tried restore iPhone without tinyumbrella: to 4.2.1 - error 3194 to 4.1 - error 3194 to 4.0 - error 3194 to 3.1.3 - 21 any suggestions ? I think that there are some hardware issue, cause I been restoring many iPhones, with different iOS, without shsh and with shsh, all went easily This time, nothing helps, |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
