itunes , error 29 , iphone 4s help required ..[solved] the phone had working well for 2 mounts and when y tried to upgrade it to iOS 7 its given me error 29 , whith the original battery the same thing happens :mad: , the phone its now in recovery mode , could anyone give me please a solution ?? tanks |
Error 20, 21, 23, 26, 28, 29, 34, 36, 37, 40 These errors typically occur when security software interferes with the restore and update process. Use the steps to troubleshoot security software issues to resolve this issue. In rare cases, these errors may be a hardware issue. If the errors persist on another computer, the device may need service. Also, check your hosts file to verify that it's not blocking iTunes from communicating with the update server. See the steps under the heading "Blocked by configuration (Mac OS X / Windows) > Rebuild network information > Mac OS X > The hosts file may also be blocking the iTunes Store." If you have software used to perform unauthorized modifications to the iOS device, uninstall this software prior to editing the hosts file to prevent that software from automatically modifying the hosts file again on restart. Br. Shashank |
i have the same problem how can we solve it ? |
here i have the same probleme with iphone 4 s . |
I have same problam plz any one help Iphone 4 restore error 3194 on ios7.0.2 |
its mostly hw,,issue,,i have ,recover it by shake ,or rebal.base band chip..u can try,, |
i have the same problem error 29 on iphone 4s.....???? |
itunes error 29 fix bro just add # in urs host file(#74.208.10.249 gs.apple.com) work like charm for me. |
I have same problem plz any one got solution Iphone 4 restore error 29 on ios7.0.3 thank's |
error 29 is battery issue try to replace battery w/ 80 percent charge or replacee a new one for error 3194 ios 7.0.2 is software issue because 7.0.2 is stop signing in server. better go for latest ios 7 of apple. |
i have same problem. iphone 4s error29 pls any solution |
change new battery and update again 100% slove |
battery problem change |
help me with this same error 29 iPhone 4S installed new battery from my other iPhone a4s but I get again and again error 29 I am installing 7.0.4 as my phone is in recovery mode since last 10 days and it's is a paper weight now:mad:mad: |
