Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 4 / 4S
iPhone 4 / 4S iPhone 4 / 4S
Old 09-27-2013, 14:04   #1 (permalink)
mighelon's Avatar
Member: 385139
Thanks Meter: 12
itunes , error 29 , iphone 4s help required ..[solved]
the phone had working well for 2 mounts and when y tried to upgrade it to iOS 7 its given me error 29 , whith the original battery the same thing happens , the phone its now in recovery mode , could anyone give me please a solution ??
tanks
Old 09-27-2013, 14:42   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 881
Error 20, 21, 23, 26, 28, 29, 34, 36, 37, 40
These errors typically occur when security software interferes with the restore and update process. Use the steps to troubleshoot security software issues to resolve this issue. In rare cases, these errors may be a hardware issue. If the errors persist on another computer, the device may need service.
Also, check your hosts file to verify that it's not blocking iTunes from communicating with the update server. See the steps under the heading "Blocked by configuration (Mac OS X / Windows) > Rebuild network information > Mac OS X > The hosts file may also be blocking the iTunes Store." If you have software used to perform unauthorized modifications to the iOS device, uninstall this software prior to editing the hosts file to prevent that software from automatically modifying the hosts file again on restart.
Br.
Shashank
The Following User Says Thank You to shashankmobile For This Useful Post:
Old 09-27-2013, 17:36   #3 (permalink)
Member: 137489
Thanks Meter: 68
i have the same problem how can we solve it ?
Old 09-27-2013, 18:16   #4 (permalink)
biaby's Avatar
Member: 523332
Thanks Meter: 172
here i have the same probleme with iphone 4 s .
Old 09-29-2013, 19:02   #5 (permalink)
PlayGsm's Avatar
Member: 888420
Sonork: 100.1611861
Thanks Meter: 344
I have same problam plz any one help
Iphone 4 restore error 3194 on ios7.0.2
Old 10-01-2013, 17:46   #6 (permalink)
mighelon's Avatar
Member: 385139
Thanks Meter: 12
you dont have the same problem , please create your own post ..
Old 10-26-2013, 20:58   #7 (permalink)
Member: 904809
Sonork: 100.1615464
Thanks Meter: 662
its mostly hw,,issue,,i have ,recover it by shake ,or rebal.base band chip..u can try,,
Old 10-26-2013, 23:31   #8 (permalink)
Member: 1804318
i have the same problem error 29 on iphone 4s.....????
Old 10-27-2013, 18:57   #9 (permalink)
Member: 745192
Thanks Meter: 10
itunes error 29 fix
bro just add # in urs host file(#74.208.10.249 gs.apple.com) work like charm for me.
Old 10-31-2013, 10:47   #10 (permalink)
cooloxf's Avatar
Member: 120893
Thanks Meter: 66
I have same problem plz any one got solution
Iphone 4 restore error 29 on ios7.0.3
thank's
Old 11-02-2013, 13:09   #11 (permalink)
Member: 563445
Thanks Meter: 17
error 29 is battery issue try to replace battery w/ 80 percent charge or replacee a new one for error 3194 ios 7.0.2 is software issue because 7.0.2 is stop signing in server. better go for latest ios 7 of apple.
The Following User Says Thank You to goku_0729 For This Useful Post:
Old 12-05-2013, 06:47   #12 (permalink)
Member: 1722835
i have same problem. iphone 4s error29 pls any solution
Old 12-05-2013, 06:50   #13 (permalink)
Member: 1704534
change new battery and update again 100% slove
Old 12-05-2013, 06:51   #14 (permalink)
Member: 1371251
Thanks Meter: 12
battery problem change
Old 12-08-2013, 12:49   #15 (permalink)
Member: 2080758
help me with this same error 29 iPhone 4S
installed new battery from my other iPhone a4s but I get again and again error 29
I am installing 7.0.4 as my phone is in recovery mode since last 10 days and it's is a paper weight nowmad:
Powered by Searchlight © 2016 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.29009 seconds with 8 queries
