11-08-2014, 08:56 | #31 (permalink) |
Freak Poster Join Date: Oct 2011 Location: pakistan faisalabad
Member: 1677616 Status: Offline Sonork: [email protected] Thanks Meter: 6 | |
11-08-2014, 08:56 | #32 (permalink) |
Member: 1677616 Status: Offline Sonork: [email protected] Thanks Meter: 6 | have same problem. iphone 4s error29 pls any solution? |
11-08-2014, 08:58 | #33 (permalink) |
Member: 1677616 Status: Offline Sonork: [email protected] Thanks Meter: 6 | I have same problam plz any one help Iphone 4 restore error 3194 on ios7.0.1 |
03-09-2015, 09:00 | #37 (permalink) |
Junior Member Join Date: Mar 2015
Member: 2359382 Status: Offline Thanks Meter: 0 | hi sorry for my bad english! yes, it is battery problem. simplest way is replacing battery. but let's be pro. the gas gauge wire on the flex makes the problem. because it's at outer side of flex cable and is very thin and disconnects easily. if someone has a healthy iphone 4s battery, share the connection way from socket to battery board. so we'll can do wiring. |
06-02-2015, 20:20 | #39 (permalink) |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | change battry 100% solution for error 29 i test 1000000% work not sol chek Video hadrwer https://www.youtube.com/watch?v=wOXmrFnDnQI |
07-22-2015, 10:46 | #40 (permalink) |
Junior Member Join Date: Feb 2014 Location: Italy
Member: 2119236 Status: Offline Thanks Meter: 3 | I have same problem. I have try to replace the battery, all condesator beep and found In the right position (R153 R61 ecc). The only thing I noticed is that the phone does not remain open with the battery attached , but have to be connected to a charger to power up in recovery mode |
03-28-2016, 08:25 | #42 (permalink) |
Cheater -Don't Deal with him- Join Date: Sep 2014 Location: indonesia
Member: 2262340 Status: Offline Thanks Meter: 1 | this hardware problem try change battery if still not working try Remove Battery and check the battery ways, there are 4 caps. Make sure that they are all in place and not damaged or corroded. If they are all in place you will need to replace the PMIC on motherboard. If you see damage to caps then you can simply remove them off a different motherboard and add to the phone you are trying to fix. |
