01-12-2011, 16:26 | #1 (permalink) | |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | How to Update iPhone 4 to iOS 4.2.1 While Preserving Old 01.59.00 Baseband for Unlock This method is known to work only with the iPhone 4, hence it may not work on other devices. The procedure seems fairly simple! We highly recommend you to backup everything on your device before following the procedure Step 1: Download the CUSTOM l iOS 4.2.1 firmware for iPhone 4 from here. MEGAUPLOAD - The leading online storage and file delivery service Step 2: Now trick iTunes into thinking that it is watching Apple servers, while in real, we are going to change the address to Saurik’s server. To do this: Navigate to C:\Windows\System32\drivers\etc\ and locate “hosts” file. Open this “hosts” file in Notepad (for Windows) or TextEdit (for Mac OS X) and add this 74.208.105.171 gs.apple.com Now simply save this file and you are good to go! NOTE for Windows 7 and Vista: Start “Notepad” with Administrator privileges by right clicking on “Notepad” app, and click on “Run as Administrator“ option. NOTE for Mac OS X: Make sure you have full read and write access on your account when you are saving the host file. If it still throws permission error, simply copy the host file to desktop, make the required changes, and then replace it with the original file in “/etc/” directory. STEP 3;open redsnow browse 4.2.1 stock firmwaer(everything u know how to go in dfu mood) Step 4: Start iTunes, click on your iOS device icon from the sidebar in iTunes. Now press and hold left “alt” (option) button on Mac, or Left “Shift” button if you are on Windows on the keyboard and then click on “Restore” (Not “Update” or “Check for Update”) button in the iTunes and then release this button. This will make iTunes prompt you to select the location for your iOS 4.2.1 CUSTOM file. Select this custom f file and click on “Open” to restore your iPhone. successfully installed on the device without the upgraded baseband. Quote:
i tested many time work for me DONT FORGET TO HIT THE thanks BUTTON | |
The Following 39 Users Say Thank You to delux_gsm For This Useful Post: |
01-29-2011, 09:25 | #15 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Sri Lanka
Member: 1074229 Status: Offline Sonork: 100.1605299 Thanks Meter: 62 | hello friends this method is 10000% working. no need to use tinyumbrella . i update firmware with this method . modem firmware is 01.59.00 . but its tethered. thanks mate |
The Following User Says Thank You to skytelecom For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
