Old 02-25-2011, 11:38   #1 (permalink)
Member: 652308
Thanks Meter: 44
error greenpois0n on iphone 4 (help)
when i start jailbreak my iphone 4
i enter it in dfu mode it start normal but at one time it say error
- unable to mount user fillesystem !
after one minute it finich but iphone stuk on logo
Old 02-25-2011, 11:43   #2 (permalink)
Member: 1030878
Sonork: 100.1602559
Thanks Meter: 19
try restore again in version 4.2.1, then activate.
jailbreak again greenpoison rc5b2
Old 02-25-2011, 11:48   #3 (permalink)
Member: 652308
Thanks Meter: 44
but if i restor it whith 4.2.1 oreginal firmware (not costome) bb mode will be upgrade to 3.10 or no because it unpgrad to 3.10 no solution unlock it right ?
Old 02-25-2011, 11:55   #4 (permalink)
Member: 1030878
Sonork: 100.1602559
Thanks Meter: 19
yes. what is the original firmware of your iphone?
what version of greenpoison did you use?
please post more details
is it factory unlocked or not?
Old 02-25-2011, 12:07   #5 (permalink)
Member: 652308
Thanks Meter: 44
i use version .
gp_win_rc5_b2
gp_win_rc6_final
same error
my iphone is not on factory unlocked
version of my iphone is 4.2.1 bb 1.59.00 how can get untethered boot
Old 02-25-2011, 12:10   #6 (permalink)
Member: 1030878
Sonork: 100.1602559
Thanks Meter: 19
boot again in redsnow
just boot tethered right now
jailbreak again in greenpoison rc5b2
if same happen you need to restore in fresh custom firmware then activate and jailbreak then do the unlocking
some tutorials http://www.iclarified.com/entry/index.php?enid=13795
Old 02-25-2011, 12:13   #7 (permalink)
Member: 652308
Thanks Meter: 44
i alredy doing it same
-what i want know that
Old 02-25-2011, 12:15   #8 (permalink)
Member: 1030878
Sonork: 100.1602559
Thanks Meter: 19
i already said yes .
The Following User Says Thank You to henrix For This Useful Post:
Old 02-25-2011, 12:18   #9 (permalink)
Member: 652308
Thanks Meter: 44
oki i will try to restor it with fresh custom firmware
Old 02-25-2011, 12:20   #10 (permalink)
Member: 1030878
Sonork: 100.1602559
Thanks Meter: 19
maybe this should help iClarified - iPhone - How to Update Your iPhone 4 Without Upgrading the Baseband (Windows) 4.2.1
Old 02-25-2011, 17:15   #11 (permalink)
Member: 652308
Thanks Meter: 44
How to Update Your iPhone 4 Without Upgrading the Baseband (Windows) 4.2.1 successe
thankx for henrix there is solution
How to Update Your iPhone 4 Without Upgrading the Baseband (Windows) 4.2.1 Sunday, 6th February 2011, 02:02 am
-1
Make sure the device is connected, and Umbrella has detected the type of device and its firmware.
**If you haven't already saved your iOS 4.2.1 SHSH blobs then click Save SHSH. Make sure they successfully save before continuing.
Step Four
Hit Start TSS Server and make sure you receive no errors.
Once The TSS Server is "running" successfully, umbrella will kill iTunes. Leave TinyUmbrella Open. You can double check to see if the TSS server is running under the Log tab.
If you do receive an error, DO NOT continue. Your restore will not work if the TSS server cannot be started.
Step Five
Open iTunes by doubling clicking its icon in the dock.
Hold down the Shift key and click Restore
Select your iPhone 4.2.1 firmware file from the popup window that appears and click Open.
Click Restore to begin restoring your device.
Step Six
iTunes should give you error 1013. This is what we wanted, as it notes the baseband has not updated Click Ok and close iTunes.
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are working with a device OTHER than iPhone 4.
Step Seven
Place your iPhone into DFU mode by holding down both the Power and Home buttons for ten seconds, then release the Power button and continue holding the Home button for another 5 seconds. You can find help with DFU mode here.
Step Eight
You are now ready to follow our Greenpois0n tutorial which will jailbreak your device and bring it out of DFU mode. **Note: You do not need to put the device into DFU mode after press the Jailbreak button in Greenpois0n as we have already done this
Step Nine
Your iPhone will now be on 4.2.1 with the 1.59.00 baseband! (Which means you can now unlock using this tutorial)
**Thanks to semaphore for his work on this tool
teste by me
Old 02-25-2011, 18:29   #12 (permalink)
Crazy Poster
Member: 1083745
Thanks Meter: 9
or you can try sn0wbreeze-2.2.1
Old 02-26-2011, 02:52   #13 (permalink)
nhumanh's Avatar
Member: 56938
Sonork: 100.1590777
Thanks Meter: 150
You can't jailbreak by greenpois0n because your phone is use custom firmware with redsn0w jailbreak.
Now, pls Restore Iphone 4 by this custom firmware : no cydia installed, noactive then use Greenpois0n jailbreak and install cydia.
Iphone 4 4.2.1 custom firmware i need
have funs
Old 02-26-2011, 06:00   #14 (permalink)
NOKIA127's Avatar
Member: 50969
Thanks Meter: 56
-1
Step Four
Step Five
Step Six
Step Seven
Step Eight
Step Nine
teste by me
this iphone doesnt have the any problems because this is att, the iphone doesnt have the ultrasnow.
mc319ll is att
but the another iphones with ultrasnow have this problemens
1 not service
2 not internet 3g
3 not youtube
Nokia127
Old 02-26-2011, 07:33   #15 (permalink)
Member: 149305
Sonork: 100.1612778
Thanks Meter: 804
try to restore again with custom firmware then use reds0w to install cydia then use green poison
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Service Provider Lock 1-4 ? StompSC Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-27-2012 11:00
Page generated in 0.40718 seconds with 8 queries
