Old 02-25-2013, 10:22   #1 (permalink)
Member: 1889863
Experts please help: iphone 4 in recovery mode loop
Hi Guys,
I have an iPhone 4 (first generation) and running on iOS4.1, baseband 2.10.4, using a Geveysim and NO shsh saved at all.
I wanted to update to a newer version of iOS while keeping the same version of the baseband (No_BB).
So I tried with Snowbreeze but itunes always returns errors such as 3194, 160x, 11 ... I used an SSL server with TinyUmbrella but still no solution.
So ultimately, I used redsnow (latest version) to restore it. And as I can save only a SHSH for the iOS version 6.1.2 so I proceeded to restore iOS 6.1.2.
Redsnow did a good job and update went well but when reboot the iPhone gets in recovery mode loop always.
I used TU, iREB but to no avail. Still in recovery mode.
Do you have any ideas how I can do now to run it again?
Thanks in advance,
Sep
Old 02-25-2013, 12:34   #2 (permalink)
Member: 457470
Thanks Meter: 159
wait for redsn0w to get updated. then u can use recovery fix. or try downgrade to 4.1
The Following User Says Thank You to mehulkr76 For This Useful Post:
Old 02-25-2013, 12:47   #3 (permalink)
Member: 1889863
Thanks Mehulkr76 !
I'm not sure if the next release of redsn0w will fix it. And I can't downgrade to 4.1 as I don't have any saved shsh file unless you have better idea.
Old 02-25-2013, 13:14   #4 (permalink)
irfan_gsm's Avatar
Member: 709520
Thanks Meter: 275
i am also have problem after update 6.1.2 on iphone 4. tyniumbrella, ireb can not kickout from recovery mode on that iphone 4
any other solution?
Old 02-25-2013, 13:41   #5 (permalink)
Member: 1086991
Sonork: 007
Thanks Meter: 19
save ur shsh 6.1.2
use iFaith-v1.5 to creat custom rom 6.1.2 for ur device
put ur device in pwned dfu mode
restor with itunes
job done
Old 02-25-2013, 13:55   #6 (permalink)
Member: 1889863
When restoring with itunes, I got always errors such 3194, 160x, 11..
I tried that for several times but with Sn0wbreeze. Should I create a custom ipsw with iFaith and tried again?
Page generated in 0.12285 seconds with 8 queries
