Old 06-26-2013, 13:29   #1 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
gevey sim iphone security code dissable .....
here is iphone 4 i want to unlock its security code but phone not factory unlock man is using gevey sim now which is best method to unlock its security code i donnt which its now firmware
Old 06-26-2013, 13:34   #2 (permalink)
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1594535
Thanks Meter: 3,421
make custome firmware and restore it with that customer firmware, baseband will preserved
Old 06-26-2013, 13:35   #3 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 115
iFaith-v1.5.6 best way same version flash and use your fone agin gevey sim
Old 06-26-2013, 13:37   #4 (permalink)
.::jagdeep-Gupta::.'s Avatar
Member: 787829
Sonork: 100.1615114
Thanks Meter: 917
try this tool for passcode- Gecko iPhone Toolkit
Old 06-26-2013, 13:39   #5 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
sure if me make custom firmware than not show itune error 3194
Old 06-26-2013, 13:40   #6 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
but me not know its present firmware
Old 06-26-2013, 14:03   #7 (permalink)
Jermainegenius's Avatar
Member: 1300324
Sonork: Spacymobileservice
Thanks Meter: 118
Use ifaith to save your present blobs from your iphone 4, use ifaith again to browse for the blobs to create a custom firmware or u could make a custom firmwsre with the latest firmware at this time which is 6.1.3, someone please write the specific step for him telling him the options and so on cause i do not have the time.
Old 06-26-2013, 14:04   #8 (permalink)
Member: 1300324
Thanks Meter: 118
Use ifaith to save your present blobs from your iphone 4, use ifaith again to browse for the blobs to create a custom firmware or u could make a custom firmware with sn0wbreeze with the latest firmware at this time which is 6.1.3, someone please write the specific step for him telling him the options and so on cause i do not have the time.
Old 06-26-2013, 14:21   #9 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
r u sure 6.1.3 is supported snoe breez which ver snow breez plz share
Old 06-26-2013, 14:34   #10 (permalink)
Moderator
Sitlay KING's Avatar
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
Use iFaith to Dump the SHSH blobs of your device,use those blob's to make a signed firmware(use same version of firmware for which you got SHSH from your device) using iFaith and do a restore in PWN dfu mode.
All iFaith and sn0wbreeze firmware are baseband preserved
The Following User Says Thank You to Sitlay KING For This Useful Post:
Old 06-26-2013, 14:51   #11 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 647
o good here good ans if me have 4s than also same plz
Old 06-26-2013, 14:55   #12 (permalink)
Aliip5's Avatar
Member: 1960926
Thanks Meter: 22
More easy method :- dowload ios 6.1.3.
Then use latest Sn0wbreeze version. Connect ur iphone with pc and close itune. Then Open snow breeze & select simple mode click brows for ios 6.1.3 file and select it. Snowbreeze will do the rest. It will create in about 15 minutes a custom ios 6.1.3 file on ur pc's desktop. Snow breeze will guide u thriugh how to put ur iohone into pwn DFU mode. When u r done in pwn dfu mode close snowbreeze. Now open itune and it will detect ur iphone in pwn dfu mode or recovery mode. Now press shift + click on restore tab , and select the custom created ios 6.1.3 snowbreeze file on ur desk top. Rest itune will restore ur iphone and it will activate ur iphone. Now done enjoy ur activated iphone.
The Following User Says Thank You to Aliip5 For This Useful Post:
Old 06-26-2013, 14:59   #13 (permalink)
Aliip5's Avatar
Member: 1960926
Thanks Meter: 22
On iphone 4s auto gevey available and will work like a charm regardless of baseband version. Update iPhone 4s to the latest ios version without any fear. ☺️
Old 06-26-2013, 15:00   #14 (permalink)
Aliip5's Avatar
Member: 1960926
Thanks Meter: 22
iFaith wont work for A5+ devices. Only support A4 and lower ones.
Old 06-26-2013, 23:38   #15 (permalink)
Moderator
Member: 1483853
Sonork: 100.1611111
Thanks Meter: 1,628
As Aliip Said,
No for ip4s,ip5 you can't preserve basebands,In ip4s and ip5 gevey sim basebands are not important you can unlock any baseband version with gevey ,Except CDMA ip4S's .
Page generated in 0.24285 seconds with 8 queries
