10-13-2011, 18:33 | #1 (permalink) |
Freak Poster Join Date: Nov 2010 Location: Surat, India
Member: 1435897 Status: Offline Sonork: Killer K Thanks Meter: 277 | ----- Guide: How To Install Winterboard On OS 5 ------ Step One Press the Cydia icon on your Springboard Step Two Press to select the Sections tab at the bottom of the screen. Step Three Press to select Networking from the list of Sections. Step Four Press to select OpenSSH from the list of Packages. Step Five Press the Install button at the top right of the screen. Step Six Press the Confirm button at the top right of the screen. Step Seven Once installation has completed successfully press the large Return to Cydia button. Step Eight Hit the home button on your iPhone to return to the Springboard. Step Nine We must now obtain the IP Address of the iPhone. To do this press the Settings button on your Springboard. Step Ten Press to select Wi-Fi from the Settings Menu Step Eleven Make sure you are connected to a wireless network then press the circular blue arrow button. Step Twelve Take note of your IP address from the Wi-Fi details screen Step Thir**** Make sure you are on the same wireless network as your iPhone and launch WinSCP by clicking it on your desktop, or in the start menu. You can download WinSCP from here. Step Four**** Once WinSCP opens, enter your iPhone's IP Address into the Host Name Field. Then enter root as your iPhone username and and alpine as the password. Then click Login. Step Fif**** You will now see WinSCP connecting to your iPhone. The first time you login using SSH, it may take 30-45 seconds. Step Six**** If a Warning dialogue pops up, click Update or Add Step Seven**** After about 30-45 seconds, WinSCP should successfully log you into your iPhone. You will be placed in the /private/var/root directory. Step Eigh**** To get to the root folder of the iPhone you can select / from the dropdown on the right side of the window. From here you can access all the folders on your iPhone for example the Applications folder Step Nine**** To transfer a file to the iPhone simply locate your local (on your computer) file using the left pane. Then navigate to the desired location in the right pane. Drag the file from the left pane to the right pane to copy the file to your iPhone. **Note** As user dlr stated, it is a good idea to set auto-lock to never. You can do this by going to Settings>>>General>>>Auto-Lock and set to never. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
