09-22-2011, 18:56 | #3 (permalink) | |
No Life Poster Join Date: Feb 2011 Location: (BaNgLaDeSh).(U.A.E,AD)
Member: 1511441 Status: Offline Sonork: 100.1604057 Thanks Meter: 1,162 | 5970 see this rules http://forum.gsmhosting.com/vbb/f456...leted-1350948/ Quote:
Restore custom firmware via itunes after no need jailbreak . custom firmware make a cydia | |
The Following User Says Thank You to riajul1988 For This Useful Post: |
09-23-2011, 01:39 | #4 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1481974 Status: Offline Thanks Meter: 42 | what I do to restore from 4.3.5 to 4.1 is this (assuming 4.1 blobs are not saved) so your iphone is running 4.3.5 what I do (if shsh blobs are not saved) is jailbreak it and run cydia until it shows on shsh saved for 4.3.5 and 4.1 THEN put phone is dfu mode and restore to 4.1 you'll get error 1015 you'd be stuck on recovery mode and your phone will have the connect to itunes icon and show up on itunes. restore to stock 4.1 again and you should get error 1015 when that finishes. use recboot or something to kick it out of recovery mode and you should be set. |
The Following User Says Thank You to alfyguy For This Useful Post: |
09-24-2011, 18:49 | #7 (permalink) |
Major Poster Join Date: Jul 2007 Location: Pakistan , LAhore Age: 39
Member: 538854 Status: Offline Thanks Meter: 3 | NO Problem Bro. Just enter in dfu mod with redsnow open redsnow and select 4.1 file of 3gs click next and than select last option just pwn enter dfu mod ok than you must change you host file with 734 byts and than flash your phone with firmware 4.1 you got err0r 1015 when you exit recovery phone not properly on in normal mod you must again flash with 4.1 firmware and than exit recovery and jailbreak your device and unlock with redsnow 0.96b6 win ok 100% tested soulution Note when you downgrade your 3gs you must Flash tow time ok take care ***** HAFIZ |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
