Old 12-15-2010, 16:13   #1 (permalink)
surendra777's Avatar
Member: 952313
Sonork: Coolboy
Thanks Meter: 26
Help my 3gs went blank & dfu mode after update & unlock with 4.2.1 redsnow 0.9.6b.5
How to recover my iphone that went blank after i updated with 4.2.1 firmware & i installed cydia & ipad baseband.Now it is on dfu mode & no display it is only dectected in itunes.
Old 12-15-2010, 16:26   #2 (permalink)
Member: 210294
Sonork: 55667777
Thanks Meter: 122
just hold home and power botton in 10 sec and your phone will power on
Old 12-15-2010, 16:40   #3 (permalink)
Member: 877354
ok will be test.......................................
Old 12-15-2010, 17:02   #4 (permalink)
Member: 296999
Sonork: not avaible
Thanks Meter: 83
i try but not done only connect sound apper in my laptop
Old 12-15-2010, 21:06   #5 (permalink)
Member: 330490
Sonork: 100.1596361
Thanks Meter: 40
The same problem with me
i can not restore again to the orginal 4.2.1 version
When I click restore goes to white screen
We need a solution
Old 12-15-2010, 21:27   #6 (permalink)
Member: 84048
Thanks Meter: 27
Just use custom firmware to restore because your modem is 6.15 u can't restore with org firmware. First step is use red snow for dfu mode and than flash with custom firmware
Old 12-15-2010, 21:43   #7 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
i met the same problem. check that the battrey is well charged when flashing the baseband. Once the process is finished leave it at least to show the apple logo again.
I am assuming you already flashed it with the original 4.2.1 and got the 1015 error before this. Then chose the option that it is a new model.
IF you did not (something that the redsnow detects anyway) the 3GS can behave really strange such as but not limited to...
1. display goes haywire after a certain amount of time
2. switching off
3. gets into DFU mode on its own
Once the baseband is flashed PROPERLY just use cusom firmware and boot tethered at the end.
Old 12-15-2010, 22:36   #8 (permalink)
Member: 1374074
Sonork: 100.1591605
Thanks Meter: 92
dfu mode solution
In my condition all phone was new brand...
but i have to take risk....
opened the phone...
disconnected bettery...
waited for 1-2 minute...
again attached....
restored with custome 4.2.1....
everything is like charm.........
second option is to wait for get ur bettery full drain....
if u dnt wanna open the phone....
Old 12-15-2010, 22:36   #9 (permalink)
Member: 330490
Sonork: 100.1596361
Thanks Meter: 40
i try flash with custom firmware
Did not succeed
Old 12-16-2010, 13:58   #10 (permalink)
Member: 210294
Sonork: 55667777
Thanks Meter: 122
i think itune host server :
74.208.10.249 gs.apple.com
127.0.0.1 gs.apple.com
is back, i downgrade all iphone who don't like downgraded with success
Old 12-16-2010, 14:34   #11 (permalink)
Member: 1467180
The solution is easy,do the hardware reset,open the phone,remove the battery then wait 15 seconds then put it back in and the issue (error 28) will go away.
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.28905 seconds with 10 queries
