08-26-2010, 00:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | help me out i recvd iphone 4g firmware v 4.0.0 for unlock i worked with this tips..jail breaked and unlocked iClarified - iPhone - How to Jailbreak Your iPhone Using JailbreakMe [4.0.0, 4.0.1] at the end of unlock stage i switched off/then on tht phone manually!! now tht phone is in "apple" mode..when i switch on!! i tried to make in dfu mode..then trying to restore it manually(shift key)wth iPhone3,1_4.0_8A293_Restore (as tht is its original firmware) while trying for restore..ERROR OCCURS!! ERROR CODE:3194 MY DOUBT IS: can i upgrade/restore it wth iPhone3,1_4.0.1_8A306_Restore, after tht,can i jail break and unlock wth the same procedure iClarified - iPhone - How to Jailbreak Your iPhone Using JailbreakMe [4.0.0, 4.0.1] kindly guide me. thankx in advance |
The Following User Says Thank You to .::koolfriend4u::. For This Useful Post: |
08-26-2010, 00:15 | #2 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1197300 Status: Offline Thanks Meter: 84 | No, you can not restore to 4.0.1 or less, you can to 4.0.2 but will break you Jailbreak and unlock. so the best thing to do, is to see if ur SHSH Svaed you can search alot of topics how to see that [TinyUmbrella] and if its saved u can restore fine. or try to fix your error, because i don't understand what you mean by "Apple Mode"? you mean the Recovery Mode? if yes then there is a Simple Fix... which is "RECBOOT" will get you out of the loop. Good Luck. |
The Following User Says Thank You to Moaead123 For This Useful Post: |
08-26-2010, 00:31 | #3 (permalink) | |
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | Quote:
"apple mode"=what i tries to say is "phone display with apple symbol @ the centre of screen" (cant able to switch off/on) what to do next?bro. pls help.. xpecting ur reply at the earliest thnkx | |
08-26-2010, 02:10 | #4 (permalink) |
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | hai iphone xperts.. help me.. i tried wth "recboot" it doesnt works for me!!might be my phone is iphone 4g firmware vrsn4.0.0 anyway to restore in normal.. thnkx in advance |
08-26-2010, 02:37 | #8 (permalink) |
Member: 200145 Status: Offline Sonork: 100.1596786 Thanks Meter: 677 | thnkx for ur reply.. i tried wth tiny umbrella v 4.02.05 "kick device out of recovery" but still phone in same state"apple logo @ centre of screen" cant able to switch off/on!! in tiny umbrella phonre detects in dfu mode.. it shows device serial number.. im having tht ecid of tht phone..as noted down,while jailbreak/unlock process earlier!! wat to do next bro? cant able to recover wth vrsn 4 or versn 4.01 too!! |
08-26-2010, 02:48 | #9 (permalink) |
No Life Poster Join Date: Feb 2003 Location: Aus. melbourne Age: 45
Member: 20639 Status: Offline Thanks Meter: 233 | on tiny embrella, sellect the right version that you have saved ECID with last time just "RUN TSS SERVER" and restore your phone you the version that you saved your ECID with. thanks |
08-26-2010, 10:39 | #10 (permalink) | |
Member: 1197300 Status: Offline Thanks Meter: 84 | Quote:
you can try to Hold the Power Button And the Home button for 10 seconds and Leave the Power button but keep holding on the HOME BUTTON. then it will send you to the dfu, after that itunes will detect the iphone.. then try to Hold the home button and the power button Only until you see the apple logo again. hope this fix. | |
08-26-2010, 10:58 | #11 (permalink) | |
No Life Poster Join Date: Feb 2005
Member: 117950 Status: Offline Thanks Meter: 139 | Quote:
08-27-2010, 08:26 | #13 (permalink) | |
but this method didnt helps me! | |
08-27-2010, 08:42 | #14 (permalink) | |
i got the message like this in tiny umbrella *** in the tiny soft mentions" devices wth ecids matching the above and restoring to the exact firmware version listed above will succeed!" but still i cant able to restore wth v 4.0.0 also cant able to do wth v 4.0.1!! ERROR REPORT OF:3194 NOTEhone comes for unlock(iphone4 versn 4.0.0),i jailebreaked and unlock via wifi..at the final stage of reboot mobile...prblm happend!! HELP MEEEEE OUT... THNKS FOR ALL UR KINDLY SUPPORT HERE Last edited by .::koolfriend4u::.; 08-27-2010 at 08:49. | |
08-28-2010, 12:21 | #15 (permalink) | |
ok try this go to c:/windows/system32/drivers/etc and open that folder there is a file there called hosts you going to edit that file open it with notepad and copy this string 74.208.10.249 gs.apple.com to the end of the documents and save it then try to restore again and make sure you download iphone4 firmware 4.0 | |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
