03-14-2012, 22:30 | #4 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Azerbaijan
Member: 622715 Status: Offline Thanks Meter: 82 | |
03-15-2012, 16:59 | #8 (permalink) |
No Life Poster Join Date: Sep 2007 Location: I donot know what is the best Age: 51
Member: 581626 Status: Offline Thanks Meter: 184 | unlock 3Gs ios 5.1 Read carfully: from iphone-magazine ( translated via google ) ultrasn0w fixer fixes problems of IOS 5.1 with ultrasn0w With Apple's new operating system iOS 5.1 was again a new baseband (at least on the iPhone 4) - 04.12.01. If you as an old Unlocker by ultrasn0w unlockbarem baseband (iPhone 4: 1:59:00, iPhone 3G: 4:26:08, 5:11:07, 5:12:01, 5:13:04 and 6:15:00, the iPad baseband) via custom firmware with redsn0w or sn0wbreeze will update to iOS 5.1, so the unlock tool is incompatible with the old baseband. The iPhone Dev team has already announced that ultrasn0w will be updated shortly and then also compatible with IOS 5.1 + is old baseband. There are however no later than the above mentioned baseband geunlockt. Not even the baseband of IOS 5.1. If you now will update with a custom firmware on IOS 5.1 and updated, so errors like "No SIM installed" occur. Or there is no connection is made to the network. The solution to this problem is ultrasn0w fixer. The developer named zmaster has released his Cydia repo tool. It is installed before installing ultrasn0w. Thus it resolves all incompatibilities of ultrasn0w 1.2.5 iOS 5.1, until the iPhone Dev Team has released a new version of their unlock tool. With this guide, you can install ultrasn0w fixer on your device with IOS 5.1 and the old baseband. NOTE: If ultrasn0w 1.2.5 already installed, it must first be removed to install ultrasn0w fixer. Step 1: Start Cydia and go to the Manage tab. Choose from sources. Step 2: Tap on the Edit button and then click the Add button. Step 3: Enter the URL Untitled Document in the pop, and then type in the Add Source. Step 4: If the sources have been updated, you can click the newly added repo the package type and select ultrasn0w fixer. Step 5: Tap on the Install button in the upper right corner of the display. Confirm the installation and wait until it is completed. Step 6: Once the ultrasn0w fixer is installed, you can install ultrasn0w 1.2.5 from iPhone Dev Team. This type in the Search tab at the bottom of the screen. Type in a ultrasn0w and install the package. Step 7: Now carry only a reboot and the unlock work on iOS 5.1 with baseband old should. You have completed the instructions for installing ultrasn0w fixer iOS 5.1 successfully. You can uninstall the ultrasn0w fixer again when a new version is published by ultrasn0w (ultrasn0w 1.2.6). |
The Following 2 Users Say Thank You to inside-d-saul For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
