12-16-2012, 20:51 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: UK
Member: 1812152 Status: Offline Sonork: 100.1621088 Thanks Meter: 4 | How to activate 4s ios5.0 without original SIM CARD Have iphone 4s on ios 5.0 Need to activate it and the use gevey but it is stuck at activation screen as I do not have a real SIM CARD. Is it possible to activate it permamently without original sim? |
The Following User Says Thank You to Mantaspantas For This Useful Post: |
12-16-2012, 23:27 | #8 (permalink) | |||
Moderator Join Date: Jan 2011 Location: Throne of GsmHosting
Member: 1483853 Status: Offline Sonork: 100.1611111 Thanks Meter: 1,628 | Quote:
guide please. Quote:
you can jailbreak iphone4s(a5) but you can't hactivate,Stop lurking just find a unlocking source or a original sim card,nothing else will help,till yet. | |||
12-17-2012, 00:44 | #9 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2010 Location: Area 51 Age: 32
Member: 1236325 Status: Offline Sonork: 100.1616831 Thanks Meter: 272 | Yes of course that have way to activate permanently i will tell u how : 1. Check imei to get carrier 2. Buy one xsim or gevey or rebelsim put with sim card and insert or write imsi to xsim and then activate throught itunes or via wireles will work 100% u can eject xsim gevey or rebel ur phone work gr8 not stuck in activation screen. |
The Following User Says Thank You to .:[Diamond]:. For This Useful Post: |
12-17-2012, 00:59 | #10 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Macedonia
Member: 1671934 Status: Offline Thanks Meter: 247 | Just turn off your iphone, then hold pressed HOME button and then while holding home put USB cable to iphone, you will enter in recovery mode. After that start redsn0w, and just click JAILBREAK, check install Cydia. If you can not do that then i do not have anything more to say. |
12-17-2012, 03:50 | #11 (permalink) | |
Freak Poster Join Date: Jan 2012
Member: 1717046 Status: Offline Sonork: 100.1619225 Thanks Meter: 46 | Quote:
2.if u can't find original sim card , just Jailbreak on 5.1.1 (Jailbreak for bypass activation ,but it's not real activation) 3.u have to looking SAM on cydia try to activate with SAM again it's fool activation without original sim | |
12-17-2012, 05:40 | #13 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1720169 Status: Offline Thanks Meter: 77 | dude you must give your imei ;) i hope you might have any turbo sim for 4s just put it in another iphone 4s select your carrier take out the sim put into non activated phone and voila dude send me your imei so i can help you with the carrier |
12-17-2012, 05:44 | #14 (permalink) |
Member: 1720169 Status: Offline Thanks Meter: 77 | ya i forgot to tell you that ios 5.0/5.0.1 has the activation by pass trick by doing 12 call it will provide u so that you can got to the sim application os so ever select your carrier from the turbo sim .... |
