How can i remove security code iphone 4? Hello , how can i remove security code on iphone 4 is it with security code? Do i have any chanse without restoring or not? And if i restore with what version can i do that? Thank you |
custom firmware whith pawnagetool mac . |
Can i update normally with 4.2.1 ipsw? Bcs no need to jailbreak or unlock? Only to remove security code? |
DFU mode solution In my condition all phone was new brand... but i have to take risk.... opened the phone... disconnected bettery... waited for 1-2 minute... again attached.... restored with custome 4.2.1.... everything is like charm......... second option is to wait for get ur bettery full drain.... if u dnt wanna open the phone |
if it say coonect to itunes so conect to the pc you first time synced with and it should be unlockt if u update u will lose all your information and it cant be unlockt |
No need to save nothing on my phone , only i want to remove security code on the iphone 4. But when i'm trying to restore by holding shift with 4.2 ipsw show me 3014 error with itunes: Thank you |
-switch off phone -press home botton and connect to PC itune will detect phone in recovery mode, so, restaure and you are done You will loose all info inside you will loose Unlock if done with RedSn0w BR, |
Nothing i need to save as i say , only i need to remove security code on the phone: But when i'm starting with itunes to restore show me error 3014 maybe is it for old itunes or what? Thank you |
127.0.0.1 localhost 74.208.105.171 gs.apple.com what i need to writte if i delete this? thank you for reply |
Now when i;m delete line 74.208.105.171 gs.apple.com show me error: 3194 |
(Occurs when trying to install an old firmware and Apple's server disallows the installation. The only solution is to have SHSH backup and modify the hosts file to point to Saurik's Cydia server where they are backed up (or localhost if you have it yourself).) That mean u have to flash with updated file. |
Thank you |
