Old 03-06-2013, 01:40   #1 (permalink)
Member: 74258
Thanks Meter: 36
how to check the version on a disabled iphone 4
(1) how to check the version on a disabled iphone 4
(2) how to check the version on a disabled iphone 4s
(3) how to check thr version on a disabled iphone 3g
(4) how to check thr version on a disabled iphone 3gs
need solutions
Thanks
Old 03-06-2013, 01:44   #2 (permalink)
Member: 743134
Sonork: 100.1661221
Thanks Meter: 34
just update use snowbreez then update....
Old 03-06-2013, 03:45   #3 (permalink)
Member: 1827802
Sonork: otto
iphone 4 heating up and no image after screen replacement, please any advice
Old 03-06-2013, 07:46   #4 (permalink)
Member: 1865200
In any case, you can use TinyUmbrella to determine what iOS revision and baseband the phone has, so long as the phone will power on in some form or another. Also, for more specific help, you may want to explain what you mean by disabled -- the iPhone can be 'disabled' in one of several ways (e.g., passcode lock wrong too many times, remotely disabled by MobileMe, IMEI blocked by the carrier, jailbroken incorrectly and bootlooped, etc.) It's going to be difficult to assist without more information about the problem, so let us know as much as you can and we should be able to help.
Old 03-06-2013, 07:49   #5 (permalink)
Member: 883911
Sonork: 234
Thanks Meter: 4
just use iphone forcast it will show you your iphone version
Old 03-06-2013, 08:32   #6 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
need solutions
Thanks
only redsn0w work disable iphone version info contact me show you how
Old 03-06-2013, 08:44   #7 (permalink)
mujie's Avatar
Member: 8304
Thanks Meter: 362
install ifunbox.Version will popup in taskbar when iphone connected
Old 03-06-2013, 09:44   #8 (permalink)
Member: 171281
Thanks Meter: 26
ifaith works well in determining the ios version of disable iphone mentioned above.
Old 03-06-2013, 10:23   #9 (permalink)
Cheater -Don't Deal with him-
Member: 1236325
Sonork: 100.1616831
Thanks Meter: 272
best way to know version in iphone is simple just 4 steps:
1. Open Redsn0w
2. Go to Extras
3. Go to SHSH Blobs
4. Go to Fetch ( put iphone in dfu mode )
and cheers u will show which version already installed in iphone .
works gr8 tested by me.
The Following User Says Thank You to .:[Diamond]:. For This Useful Post:
Old 10-14-2015, 00:05   #10 (permalink)
VIJAYMOURYA's Avatar
Member: 712406
Sonork: 100.1651933
Thanks Meter: 251
1. Open Redsn0w
2. Go to Extras
3. Go to SHSH Blobs
fetch option is not enable..what to do now.phone is in dfu mode
The Following User Says Thank You to VIJAYMOURYA For This Useful Post:
Old 10-16-2015, 04:41   #11 (permalink)
Member: 1738539
Thanks Meter: 11
There is one box HDBOX which have LCD can show the version of the disable Iphone.
You can search on the YOUTUBE for "HDBOX iPhone usercode"
The Following User Says Thank You to daneremail For This Useful Post:
Old 10-20-2015, 23:54   #12 (permalink)
Member: 1738539
Thanks Meter: 11
There is a TFT LCD on the HDBox. It can show the version of the iPhone(disable iPhone included). You can see that at wetsite hdb-team com
Page generated in 0.24503 seconds with 9 queries
