02-18-2013, 16:38 | #4 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2010 Location: Area 51 Age: 32
Member: 1236325 Status: Offline Sonork: 100.1616831 Thanks Meter: 272 | use search button brother u will find Gecko toolkit to remove disabled and read passcode about 20 mins u will solve this problem . |
02-18-2013, 16:51 | #5 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Quote:
so pls any solution | |
02-18-2013, 19:27 | #7 (permalink) |
Moderator Join Date: Feb 2006 Location: Bangladesh & Bahrain
Member: 233205 Status: Offline Thanks Meter: 5,014 | this the thread for Gecko Toolkit- http://forum.gsmhosting.com/vbb/f456...olkit-1424749/ read this full thread all post u will get several problem and solution. you need "microsoft .NET Framework 4" and "java" installed on ur pc,,win7 work good for me. first u have to remove "iphone disabled" after successfully remove iphone disable u will see normal iphone pass code lock screen then next u need to read lock code and put it manual by pressing phone keyboard. its tested and working don't worry just u need to try and make its working for your pc removing iphone disable and read lock code by this soft u don't loss any personal data. but if u will restore fw by itunes u will lose all of your data. |
The Following 2 Users Say Thank You to tkowsar For This Useful Post: |
02-18-2013, 20:43 | #9 (permalink) |
Member deceased !! Join Date: Jan 2008 Location: DreamSunlock Canada,TH,CN,BD Age: 36
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks Meter: 1,348 | no way to backup bro,1st phone off then press & hold home button insart usb after few sec show recovery mode,2nd open itunes press & hold shift button in pc then click restore select restore file click restore after few time alldone.thankssssssssssssssss |
02-19-2013, 07:18 | #11 (permalink) | |||
Member: 233205 Status: Offline Thanks Meter: 5,014 | Quote:
why u giving wrong information to user? if u don't know then no need to reply user thread with wrong information,,,just read and learn first please. iphone2g, iphone3g, iphone3gs & iphone4 you can remove "iphone disable" and read lock code with "Gecko Toolkit" without losing your personal data. tested working thousand time without any error. and this user phone is iphone4 as he mention in his 2nd post in this thread. understand? | |||
The Following 3 Users Say Thank You to tkowsar For This Useful Post: |
02-19-2013, 11:27 | #13 (permalink) | |
The Following User Says Thank You to Shantobhai For This Useful Post: |
02-19-2013, 15:01 | #14 (permalink) |
Member: 233205 Status: Offline Thanks Meter: 5,014 | its java problem,,,have u install java in your pc? i have told u to read full thread all post of gecko toolkit thread. have u? you need to apply patch for java which solve conflict java with nokia jar file,,,which also contain with his thread. its have some last fix version,,,try them all. |
02-19-2013, 15:28 | #15 (permalink) | |
yes all ready do this [jre-6u21-windows-i586-iftw-rv]java but same, pls tell me any other solution... | |
