How to choose correct carrier with R-sim 9 pro Hello guys i have one iphone 4s Locked to Vodafone - Portugal i buy r-sim 9 pro ... And i have a question next install new card in phone with r-sim 9 apeer one menu to choose carrier... Wath carreir i need choose ? Default carrier from iphone or new carrier ? In my case i need to put manually the numbers of carrier because no apeer in menu... I put default carrier... and now i cant change... i want change to another carrier to new carreir... Wath i need do ??? How i can fix it ? |
rsim Hi you must put manualy the right imsi for the Carrier you have imsi-Portugal Vodaf 2680111 to go to menu again put onother sim card choose default Carrier restart and then put the sim card you want to use |
another question about r-sim R-sim 9 pro works in iphone 4s with ios 7.0.6 ? And my iphone is from Vodafone - Portugal I want use one card from TMN - Portugal Wath carrier i need put in menu to use card from TMN - Portugal ? I try put numbers manualy from Vodafone - Portugal, and when i insert card from TMN not apeer any signal... only say searching all time... Any idea ? |
can you answer me when you are available ?? |
rsim Hi you must chose from the manu. other carriers put the imsi i gave you and make restart |
Didnt work.... Hello r - sim didnt work ... always say searching signal... any resolution ? |
You need to select the carrier that the phone was ORIGINALLY on- NOT the carrier you're trying to put it to. Otherwise it won't do the activation unlock properly. Oh, and then you need to go (on the phone) to www(dot)rsim5(dot)com/nano4g and install the nano4g patch If it doesn't work then, you need to jailbreak it and go to the cydia repo www(dot)isamteam(dot)com and install the two patches that have to do with the iphone 4s. Everything's in Chinese, but it's like the 3rd one down and one of the last ones, like K. Just look at the names of the patches and install the ones that have to do with the 4s. |
