06-28-2012, 05:51 | #1 (permalink) |
No Life Poster Join Date: May 2012 Location: Insite IC
Member: 1757379 Status: Offline Sonork: no need Thanks Meter: 400 | How To Fix Absinthe Jailbreak iOS 5.1.1 issues ? We will fix many issues that faced our readers while trying to untethered jailbreak iOS 5.1.1 on their devices How To Fix “HTTP/1.1 500 Internal Server Error “HTTP/1.1 500 Internal Server Error” faced our readers when trying to download Cydia packages this error is because many people are trying to access Cydia at the same time in order to complete their untethered jailbreak iOS 5.1.1 How To Fix: the fix of this issue is so easy all you have to do is to wait for minutes or hours then try again , there’s too much traffic on Cydia. How To Fix “Lock Down error -5 : We have received many comments on our Absinthe Jailbreak.com regarding an error message called “Lock Down error -5” in my opinion i think that in order to get a clean jailbreak i mean jailbreak without errors you have to restore your device first before starting your iOS 5.1.1 untethered jailbreak How To Fix: You have to reset factory setting your device, BEFORE you use the new absinthe . then try again How To Get Clean Jailbreak [Jailbreak without Errors] : In order to get the best jailbreak result when you decided to jailbreak untethered iOS 5.1.1 you have to restore your device first then use the video below its a good video to jailbreak your device without errors and also check our links **** Note: if you decided to restore you can use our Guide to back up your Device Via iTunes or iCloud to keep it away from losing. How To Fix “Sorry, the attached device is not supported : use last ver Absinthe 2.04 OR So if you are using one of the above devices and you still get this message so try to reboot your device and change the USB port then disable the start up applications and try again follow the steps below we will show you how Step 1: Click “Start” then select “Run” Step 2: Then Write “msconfig” and click “Ok” Step 3: you will be informed by the screen below then select “Startup” and disable all the startup application Fix Absinthe 2.0.4 No Cydia icon after Jailbreak : After Jailbreaaking your iPhone / iPod / iPad You have to wait until Absinthe complete the jailbreak process. and that is because the huge Traffic these days which needed to install Cydia App at the same Time. You must know that Absinthe takes time to install the file. If after several tries and waiting period it does not show up , there is something wrong with the jailbreak or the process. try running it in Administrative mode if on a PC Fix Absinthe No Reboot or Stuck on Waiting for Reboot: Also If you are using Absinthe 2.0 try to Download Absinthe 2.0.1 to fix the problem with your jailbreak . and Try Unplugging the Device from the USB and try Manual Reboot it and it will be fixed We think that after doing the above steps it will fix your issue if not please let us know in comment Section |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
