Old 04-15-2013, 11:20   #31 (permalink)
rizoo's Avatar
Member: 375590
Thanks Meter: 44
Originally Posted by FORUM-FON View Post
Pls Explain Here Bro with Step by Step Procedure .
Witch Version ?
Download Sn0breeze Here iH8sn0w.com: sn0wbreeze v2.9.8/2.9.9/2.9.10/2.9.11/2.9.12/2.9.13/2.9.14
Then run sn0wbreez Select IPSW 6.1.3 then click next and select Simple Mode on next windows, select Activate yes if not unlocked otherwise skip this option, after creating custom IPSW (it's takes some minutes) then open ITunes and using Shift Key select Custom IPSW from your Desktop. restore completes and enjoy it.
Old 04-15-2013, 13:19   #32 (permalink)
Member: 1834434
Thanks Meter: 9
it is vry simple change pc and data cable it will be done 100%
Old 04-15-2013, 15:52   #33 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 214
Originally Posted by gsm_revolution View Post
For sure and 100% baseband curropt change baseband and your problem will be solved
It is not a corrupt baseband, it is an invalid baseband. If that is happening, then you need to either flash the old fw version (if blobs saved), or fully upgrade the phone including baseband.
This happens when there is a baseband version mismatch.
Old 04-16-2013, 07:31   #34 (permalink)
Member: 1718734
Ya ,I try To Downgrade But After Show Error 3194
i own 4 apples repaire stores and ive ran into this problem lots you are on a windows computer try to find one with XP and use it or try and find a mac this will fix
Old 04-16-2013, 08:10   #35 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 568
Thanks
My Cable 100% Perfect
Becoz I Update Another 4 & 4s Bro .
use snowbrez file ... i think imei crupt
Old 04-16-2013, 11:57   #36 (permalink)
FORUM-FON's Avatar
Member: 1832100
Thanks Meter: 55
I Try to This U r Steps . Then Update Complete , But After Only Apple Logo on Phone .
Already i Try to Change PC & Cable But After Same Problem ...!
How to Upgrade Baseband ..?
I Use This File ( sn0wbreeze_iPhone_4-GSM-6.1.3-10B329.ipsw )
But After Only Apple Logo @ Phone
How to Solve This Problem
Old 04-18-2013, 20:44   #37 (permalink)
Member: 690160
Sonork: 100.1583287
Thanks Meter: 14
Bro just only 2 ways cause i faced this problem many many times
if flashing stopped at middle and give u error -1 when u remove phone
1- try to flash phone by mac not pc
2- try to flash custom firmware
only this ways can solve flashing error
Old 04-18-2013, 20:56   #38 (permalink)
Member: 1327995
Thanks Meter: 4
flash the main board with battery only tested 100%.
Old 05-19-2013, 07:41   #39 (permalink)
Member: 1296637
Thanks Meter: 96
Another approach to solve the problem.
Please visit this link.
iPhone4 No IMEI ??? Error-1 ???? ???????? IOS6 ????????? ???????? !!!
Old 05-19-2013, 07:57   #40 (permalink)
Member: 1724015
Thanks Meter: 33
Basband ic problem.....................
Old 05-19-2013, 08:11   #41 (permalink)
hekmat-safi's Avatar
Member: 961188
Thanks Meter: 37
it is not Country Lock it is hardware bro 100% bb ic
Old 05-20-2013, 20:57   #42 (permalink)
Bi0H4z4rD's Avatar
Member: 52560
Thanks Meter: 214
Simple, just connect phone to itunes in DFU mode and let itunes update to the latest version available.
No need to change baseband IC, no need to walk backwards or put phone into the fridge to fix.
Old 05-21-2013, 11:12   #43 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 9,575
First i'm having always this Error -1 in 3Gs, phone forever in Recovery Mode, when have changed the battery, now 3Gs start whith Restore mode, also in iTunes, have download the latest fw 6.1.3 for 3Gs and have put in the Itunes Update Folder.
Now phone Start in Recovery Mode and iTunes to see this phone, start whith procedure for restore but when arrive 80/90% have always Error 29, no more Error -1, iTunes Support write that is "Protection Error", but have disabled Firewell and all others Block, also Antivirus, but this Error 29 remain.
For put in DFU Mode, how to if not can power off the phone?, always have need of disconnect Battery, opening the iPhone?, in the Logs i read that the new fw writing for one good 85/90%, block at the end, when will be reboot in normal mode.
Have any solution?
Thank in Advance,
br
Old 05-21-2013, 17:02   #44 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
this one same base band problem hope they will added this
Old 05-22-2013, 09:18   #45 (permalink)
Member: 1834434
Thanks Meter: 9
change battry and change pc it will done
Page generated in 0.33390 seconds with 8 queries
