how to Fix iPhone Battery Drain After Jailbreaking and Unlocking how to Fix iPhone Battery Drain After Jailbreaking and Unlocking By syria4Soft ============ [IMG]http://www.**********.com/000/ALL%20PHOTO%20OF%20BOXES/small_2/IPHONE.jpg[/IMG] ====================== As we reported earlier this week, some of you who have recently updated your baseband to 06.15.00 to jailbreak and unlock have been facing battery drains issues. The problem doesnt actually come from UltraSn0w or RedSn0w, but from the hacktivation process, for those of you who have hacktivated instead of activating the phone with an official carrier. The issue comes from iOS 4.1 and 4.2.1 which constantly look for valid push certificates, either via wifi or your data plan (Edge or 3G). This runs down you battery and may even cause your iPhone to overheat. If you didnt hacktivate your iPhone but simply activated it with an official carrier (ie AT&T in the US), you shouldnt have any problem. If on the other end you did hacktivate your iPhone, you might be experiencing the battery drain issue. Fortunately, there is now a fix for it Developer @sbingner (author of TetherMe) has made some excellent progress devising a new hactivation method that kills two birds with one stone for all you ultrasn0w unlockers. His tool, Subscriber Artificial Module (SAM) tricks your iPhone and iTunes into creating legitimate activation tickets even though youre unlocked with ultrasn0w. This means you get the full benefit of push applications, and your battery life increases substantially. Sbingner explains on his website how to fix this problem by tricking your iPhone and iTunes: Step 1: Add the following repo in Cydia: http://repo.bingner.com Step 2: Install SAM and SAMPrefs from this repo. Step 3: Now were going to revert to a stock lockdownd for SAM to function. To do so, download RedSn0w 0.9.6b6 from our downloads section, launch RedSn0w and select the Deactivate option. This will remove the normal patches made to lockdownd and let SAM take over. Step 4: Go to Settings > SAM, then click De-Activate iPhone. Step 5: Make sure iTunes is on, plug your iPhone and let iTunes activate your iPhone. If iTunes says Invalid SIM, you will need to manually select a carrier under Seetings > Carrier. At this point, you may unlock using UltraSn0w if necessary (see our UltraSn0w tutorial here). This fix will allow you to get the full benefit of push applications while increasing your battery life substantially. ============ [IMG]http://www.**********.com/000/ALL%20PHOTO%20OF%20BOXES/small_2/IPHONE.jpg[/IMG] ====================== |
sweet thanks buddy i just unlocked my 3g the other day and i could sit there an watch my battery go down it was freaking crazy. i thought at first it was because i installed tomtom on it. so i deleted it an had the same problem this is a huge fix props to you!! |
i tunes not activate my iphone 3gs i tunes not activate my iphone 3Gs i do all step all its ok but now itunes say invalid sim :mad: i have 3gs 4.2.1 bb 6.15 its unlocked and work normaly but tethered please help how can i activete with itunes;) |
Need some help please So I follow step 1-3 but I don't see sam in the setting |
hier link for bulgarien user Активация на ФЗ телефон без оригинална SIM карта - BG iPhone |
thank you verry much |
Still having drainage issues. Last night my battery was at 75% and this morning was at 46%, pretty big drop for 8 hours of stand by. My phone is unlock and I following the SAM hack, could I have done somehting wrong? |
****! My country is not there palestine wtf should i do now? |
from where i can download redsnow? |
when you click on setting if you using 3g then scroll down u can see general,phone,safari etc - scroll down bit more you will see SAM Quote:
Nothing worked. I tried restoring, installing sbingner tool and activate using itunes, but the battery still drained. I tried over and over until the iphone got stuck that no restore was possible ( I got error 21 or 1600 whenever I tried to restore ) THE ONLY SOLUTION THAT WORKED EVENTUALLY was the following one: 1. I used redsn0w to get the iphone into DFU mode - that solved the restoring problem 2. right after restoration using custom firmware of 4.2.1 I used an original AT&T sim to activate the phone using itunes. 3. I then installed a push using application like facebook and signed in. 4. only then I used the redsn0w tool to install cydia. 5. I installed ultrasn0w and replaced the sim NO MORE BATTERY DRAINING. Cheers and good luck |
how to Fix iPhone Battery Drain After Jailbreaking and Unlocking Great, Nice post .......... Thx |
Great stuff! Took me forever to figure this one out. Not to mention the additional usage charges and overheating :( Here's another step-by-step guide how to use SAM to properly activate the phone: Fix iPhone battery drain, overheating, GPS - including iTunes SIM not supported problem |
