10-26-2010, 16:15 | #32 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
Take care ENJOY | |
11-03-2010, 14:07 | #33 (permalink) |
Freak Poster Join Date: May 2006 Location: Addis Ababa
Member: 279453 Status: Offline Thanks Meter: 29 | any solution for 4.0 and 4.1 iOS? and still no solution if you can not see the carrier before starting the procedure. i guessed 3 or 4 carriers and modified the file but no luck |
11-03-2010, 16:47 | #34 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Quito Ecuador
Member: 50969 Status: Offline Thanks Meter: 56 | Quote:
Nokia127 | |
11-11-2010, 02:55 | #35 (permalink) |
Junior Member Join Date: Mar 2009
Member: 991819 Status: Offline Thanks Meter: 0 | thank you very much for the info. It worked on iphone 4 AT&T unlocked and using it on vodafone egypt. Had to restart a couple of times before it worked. For people using iOS 4.1 please run this deb. Mine worked after installing this deb and following the instructions on this web site. Patch for CommCenter iOS4 V.4.1 on 3G/3GS/4G - xSellize Credit for the deb goes to WORTEL at XSELLIZE. as usual I am not responsible for any mishapps. Thank you Kamiran for sharing excellent work thank you wortel for the deb. Enjoy |
04-05-2011, 16:04 | #36 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1549997 Status: Offline Thanks Meter: 0 | i found another site that just told me to enter (<key>AllowEDGEEditing</key> <true/>). I did this using ifile this does work but my internet teathering dissapears (not too conserned about that) but then about a week later my data network settings go away. i check ifile and the editing is still there. so i have to restore and this is a pain since i have to rejailbreak. please help |
06-14-2011, 10:12 | #37 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 42
Member: 77706 Status: Offline Thanks Meter: 26 | hi. one important piece of info is mising from this thread. if you activate the phone using redsnow, in settings, general, about you will get carrier not available.in this way, you will not be able to make this solution work. what you need to do is: reflash iphone, activate it with original sim (or with onesim programmed to your original carrier),then jailbreak, then patch commcenter.this way you will see the carrier in settings-general-about. next, the easiest method will be this : navigate to /private/var/mobile/Library/Carrier Bundles/ in your iphone (using ifunbox or whatever) and delete everithing in that folder. then replace it with all the content of your carrier.you can find your carrier folder in /System/Library/Carrier Bundles/. this way, you will see that settings-general-about-carrier will change instantly to the one you want.reset network settings and you are good to go. this is tested by me on 2pcs iphone 4 4.3.3 , 1.59 also, the commcenter patch i used i got it from cydia, using this repo : http://cydia.myrepospace.com/fosseperme/ br |
The Following User Says Thank You to sirlai For This Useful Post: |
07-27-2012, 22:26 | #40 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1790394 Status: Offline Thanks Meter: 0 | I have a Korean iPhone 4(GSM) iOS 5.1.1(9B208) BB 04.12.01 which is unlocked officially by my service provider (KT) but after jailbreaking it, I lost the ability to use my iPhone with a different SIM card which was working fine previously before jailbreak. Tried unjailbreaking and restored my iPhone and it was all good again. Rejailbreak my iPhone and the problem is the same. It's able to detect my SIM but when I tried to connect it to a network manually, it says that I'm unable to connect to the network because it's a restricted network. It keeps on showing "Searching..." or "No Service" on my statusbar?? Is there anyway to fix this? What is the problem actually? Can someone tell me what to do? TQ |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
