05-01-2013, 11:33 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1928416 Status: Offline Thanks Meter: 0 | How to get IMEI using Serial no. Iphone4? I bought a second-hand iPhone4 but I can't get it activate or hactivate. (Itune message: There is a problem with your iPhone.) Problem is I want to run the IMEI numbers through checkmend to make sure they are not blocked. The sim tray is not original and I don't have the box. I can open the phones from My Computer and found the serial number from there, now is there anyway I can get the IMEI from the serial number? SerialNumber: 82031UNRA4T Any help would be appreciated! Thanks |
05-01-2013, 18:35 | #4 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: ALGERIEN
Member: 19423 Status: Offline Sonork: 69566 Thanks Meter: 246 | Quote:
no need to open or software just see on slot off sim | |
05-02-2013, 07:06 | #6 (permalink) | |
Member: 1928416 Status: Offline Thanks Meter: 0 | Quote:
Thanks anyway. It doesn't have its original sim tray, the sim tray don't have the IMEI printed on it. | |
05-02-2013, 07:18 | #7 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
Dear Member... Model introduced: 2010 Serial number: 82031UNRA4T Number of lookups done last 30 days: 0 You will be limited to 10 lookups per 30 days. Machine Model: iPhone3,1 Name: iPhone 4 (GSM - UMTS) ModelCode: iphone_4 Family name: A1332 Model Number: MC605 Group1: iPhone Group2: Generation: 4 CPU speed: 1.0GHz Screen size: 3.5 inch Screen resolution: 940x640 pixels Colour: Black Production year: 2010 Production week: 31 (August) Production number: 33141 (within this week) Model introduced: 2010 Capacity: 32GB Factory: 82 (China) | |
05-02-2013, 08:08 | #11 (permalink) |
No Life Poster Join Date: Jul 2004 Location: GEORGIA,Tbilisi
Member: 75765 Status: Offline Thanks Meter: 722 | @ ImNoob It explains iTunes error message now . It seems that it has corrupted/damaged baseband firmware, or it might be hardware damaged as well . You should do a restore and try to activate or view that info after restoring . And if you dont want to end up with a phone not turning on at all, check the hardware before restoring . Regards |
05-02-2013, 15:15 | #14 (permalink) | |
can you point out which of the hardware i should check? Missing Battery Bracket Holder & WiFi Antenna Cover inside the iphone. The logic board is clean, no corrosion. @lancer_ali I have tried restoring it in iTune many times but I away get the Itune message: There is a problem with your iPhone. | |
