05-03-2014, 20:30 | #1 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 815509 Status: Offline Sonork: jaghori Thanks Meter: 48 | how to hacktivate ios.7.1.1 iphone4 wifi dont works |
The Following 2 Users Say Thank You to naslejavan For This Useful Post: |
05-06-2014, 15:26 | #2 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | after hacktivate no service problem. but hacktivate tool not work on ios.7.1.1 |
The Following User Says Thank You to naveed ali For This Useful Post: |
05-06-2014, 19:12 | #3 (permalink) | |
Junior Member Join Date: Aug 2010 Location: London, United Kingdom Age: 40
Member: 1361021 Status: Offline Thanks Meter: 24 | Quote:
Keep in mind, the iOS Soft Dev Pack Tool will not work on iOS 7.1.1, it will brick the iPhone 4 into a boot loop. 1. Download and install Java Development Kit (32 bit) 2. Download and extract GW_iCloud_Bypass.rar 3. Put your iPhone 4 into DFU mode (search on Google if you don't know how) 4. Start SSH.jar and wait until you see Success! written with green in the log there, also the iPhone will show the Apple logo with a grey horizontal line on its sreen 5. Open WinSCP and input, host name 127.0.0.1, port 2022, user name root, password alpine and press login 6. In WinSCP look for Terminal and open it, then execute command mount.sh, make sure the terminal says "Mounting /dev/disk0s1s1 on /mnt1" and “Mounting /dev/disk0s1s2 on /mnt2" then close Terminal. 7. In WinSCP right explorer pane, navigate to /Mnt1/Applications and delete Setup.app folder 8. Close WinSCP and SSH.jar and hard reset your iPhone 4 by holding home and power buttons until the screen goes black and release the buttons 9. Open TinyUmbrella and wait for your iPhone 4 to show as a recovery device (weird name), click on it and click exit recovery, your iPhone4 should boot normally into the home screen B. The following method promises to hacktivate almost all iOS devices including carrier signal, this is still in testing but come and test if you want. The second testing session starts tonight 06.05.2014 at 23:00 CEST 1. Check out DoulCi - BACK 2. Follow @AquaXetine on Twitter for live updates on the situation 3. This is a free tool and very easy to use, no downloads, only hosts file editing and iTunes, check out this GUIDE on how it's done 4. If it worked for you, appreciate the hard working people by donating to them on DoulCi - BACK I hope this information helped you out Last edited by pkkilleru; 05-06-2014 at 19:21. | |
The Following 15 Users Say Thank You to pkkilleru For This Useful Post: |
05-07-2014, 09:19 | #5 (permalink) | |
The Following User Says Thank You to pkkilleru For This Useful Post: |
05-07-2014, 15:33 | #9 (permalink) | |
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Quote:
The Following 2 Users Say Thank You to naveed ali For This Useful Post: |
05-08-2014, 18:18 | #14 (permalink) | |
No Life Poster Join Date: May 2007 Location: IN {HUMEN}WORLD
Member: 510445 Status: Offline Sonork: 100.1638301 Thanks Meter: 353 | Quote:
05-11-2014, 14:02 | #15 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Abidjan
Member: 38050 Status: Offline Thanks Meter: 61 | Hi ! I use Soft Dev Pack for step 2,3,4,5,6 (in dev tool 1-Run SSH_RD Tool and 2-Run SSH connect only , don't continue if your phone is on ios 7.1.1 it kill boot).Go back to pkkilleru's post step 7. |
The Following User Says Thank You to dan0007 For This Useful Post: |
