11-24-2013, 13:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 705727 Status: Offline Thanks Meter: 61 | how install deleted Cydia from apps 2) get the latest copy of cydia from Saurik.com (make sure you get the cydia_x.x.xxx_iphoneos-arm.deb version)(I also attached the latest as of this posting) 3) get the file attached here called essential_0-1_iphoneos-arm.deb 4) sftp the files over to your iphone /var/stash folder 5) ssh into your phone as root, cd over to the /var/stash folder 6) run this command: Code: dpkg -i essential_0-1_iphoneos-arm.deb cydia_x.x.xxxx_iphoneos-arm.deb 7) run this command Code: respring 8) open up cydia, it should now work Attached Files Attached Files File Type: zip essential_0-1_iphoneos-arm.zip (749 Bytes, 3717 views) File Type: zip cydia_1.0.3044-66_iphoneos-arm.zip (615.0 KB, 3631 views) ))))))))))))))))))))) step 1 downloaded both files step 2 copied both files to rawfilesystem /Var/Stashfolder step 4,5,6 I didnt understand how to run command in phone or pc pls explain little clearly pls help me |
