12-17-2012, 06:26 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | how to jailbreak 3gs after downgrade at 4.1? i try to restore with cfw but everytime i got different errors,so i restore it 4.1 original firmware, now how to activate it and jailbreak? |
The Following User Says Thank You to zeeshan tayyab For This Useful Post: |
12-17-2012, 06:38 | #2 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | If you in recovery mode kick out from recovery using fix recovery in reds0w or ireb or tiny umbrella After use limera1n to jailbreak. You can also jailbreak with redsn0w 9.6b5 Rest of process you may know if any problem !! Post here i will help . GSM-DOCTOR |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
12-17-2012, 07:10 | #6 (permalink) |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | i did that all process but it is not activated by itunes bcoz when i put ulrasnow files and restart it the both files are disappeared and then nothing to activate, how to fix it? |
12-17-2012, 08:51 | #9 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Read again : http://forum.gsmhosting.com/vbb/9023440-post4.html |
12-17-2012, 10:13 | #12 (permalink) |
No Life Poster Join Date: Apr 2012 Location: < Man is stronger than stone.>
Member: 1744389 Status: Offline Sonork: 100.1657056 Thanks Meter: 215 | use another way, with ifun box, install deb file, auto install an deb file, we supose you already have 06.15.00 or 05.1304 baseband installed, cause it wont work.. find ultrasnow 1.2.4 deb file, together with substrate safe mode, cause the latest ultrasnow will crash springboard on 3g 4.1 ios.. here the link: ultrasn0w_1.2.4.deb find how to install deb file on cydia..super easy 100% will work, its my way of unlock 3g ios 4.1// all the best.. |
12-18-2012, 12:31 | #15 (permalink) | |
No Life Poster Join Date: May 2007 Location: Kolkata<<<India
Member: 505794 Status: Offline Sonork: 100.1627614 QQ:1958018248 Thanks Meter: 2,266 | Quote:
have u solved ur problem if not u can contact me over sonork 1586029 | |
