03-09-2012, 05:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Toronto, Canada
Member: 1430995 Status: Offline Sonork: 100.1613203 Thanks Meter: 312 | How to Jailbreak iPhone 4, 3GS iOS 5.1 with RedSn0w Apple pushed iOS 5.1 firmware for iPhone, iPad and iPod Touch yesterday. Thanks to the iPhone Dev-Team for RedSn0w 0.9.10b6 which jailbreaks iOS 5.1 on iPhone 4, iPhone 3GS, iPad 1 and iPod Touch 4G, 3G. IMPORTANT It’s a tethered jailbreak which requires you to connect your device to your computer, every time you reboot your device, and use “Just Boot” feature in RedSn0w to boot in into jailbreak mode. If you turn on the device without using “Just Boot” feature, jailbreak apps won’t work (neither will Safari). Untethered jailbreak for iPhone 3GS (old Bootrom). UltraSn0w unlockers MUST create a custom firmware with RedSn0w and then jailbreak using this guide. Let’s jailbreak iPhone 4 and iPhone 3GS iOS 5.1 with RedSn0w… How to Jailbreak iPhone 4, 3GS iOS 5.1 with RedSn0w: Step 1 Download RedSn0w 0.9.10b6 for windows Download iOS 5.1 Download iTunes 10.6 First of all backup your iPhone 4 or iPhone 3GS personal data via iTunes before restoring to iOS 5.1. Attention IPhone Unlockers UltraSn0w or Gevey SIM dependent iPhone users MUST preserve their baseband before restoring iOS 5.0.1. You can do that by creating a custom firmware with RedSn0w. *** iPhone unlock dependent users MUST always use custom firmware instead of Stock iOS firmware. Step 2 Connect your iPhone 4 or iPhone 3GS to your computer, open iTunes, hold down the Shift (Windows) or Alt/Option (Mac) key and hit the Restore button on iTunes and then browse and select the downloaded iOS 5.1 IPSW file (Unlockers MUST use Custom Firmware). Step 3 After restoring process has completed; Run RedSn0w; Click Jailbreak; Now make sure your iPhone, iPad or iPod Touch is turned OFF and Plugged in to your computer. Hit Next. Step 4 Now follow the on-screen instructions to enter your device in DFU mode. Hold Down The Power (Corner) button for 3 Seconds Without releasing the Power button, also hold down the Home (Bottom Center) button for 10 seconds Without releasing the Home button, release the Power button BUT KEEP holding the Home button for 15 seconds Step 5 Once your iPhone 4 or iPhone 3GS is in DFU Mode, check “Install Cydia” and hit the next button. RedSn0w will start jailbreaking it, which should be completed within few minutes. That’s it! Once done, your iPhone 4 or iPhone 3GS will be tethered jailbroken on iOS 5.1 firmware. Now let’s talk hot to tether boot it, because without tether boot, you won’t be able to use the jailbreak features, even Safari browser. How to Tether Boot Run the Redsn0w Hit Extras, then Just Boot. Hit next, follow the on-screen instructions to enter into DFU mode. This should boot your iPhone 4 or iPhone 3GS into tethered jailbreak mode. Don’t forget to repeat the tether boot process every time you reboot your device. |
The Following 2 Users Say Thank You to cal_guy For This Useful Post: |
03-10-2012, 20:54 | #2 (permalink) |
Freak Poster Join Date: Dec 2008
Member: 929132 Status: Offline Sonork: ranaboby Thanks Meter: 27 | If you use ultrasn0w for your carrier unlock, be sure to use a custom IPSW to get to 5.1 first! Don’t ever restore to a stock Apple IPSW! Use redsn0w’s “Custom IPSW” button to create a NO_BB_* version of the 5.1 IPSW and restore to that instead of the stock one. (That option is available only to 3GS and iPhone4-GSM owners.) ultrasn0w itself will be updated for 5.1 in the next few days (same baseband support, not 5.1’s baseband). To make it clear ultrasn0w 1.2.6 won’t be a new unlock for higher basebands, ultrasn0w 1.2.6 will bring compatibility with iOS 5.1 to unlock the already unlockable basebands. Ultrasn0w 1.2.6 to unlock iPhone 4 / iPhone 3GS on 5.1 for the below basebands: 01.59.00 04.26.08 05.11.07 05.12.01 05.13.04 06.15.00 According to iPhone Dev-team, ultrasn0w 1.2.6 will be released within the few coming days. You will be able to download ultrasn0w 1.2.6 to unlock your iPhone 4 or iPhone 3GS from Cydia after jailbreaking on 5.1 using custom firmware (MUST be custom firmware), |
The Following User Says Thank You to ranaboby For This Useful Post: |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
