09-12-2011, 01:28 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 629260 Status: Offline Thanks Meter: 74 | how to upgrade 3.1.3 bb 06.15.00 i had upgrade may iphone 3g to 4.2.1 but aftr restart phone was stuck on apple logo ........to get out of this situation i downgrade my iphone to again 3.1.3 but know the bb .upgrated .....phone is work very fine but some of application not suported to ois 3.1.3 ...i want to again upgrade on ois 4.1.0 tell me any one how i can do this .............help me |
09-12-2011, 02:48 | #2 (permalink) | |
Freak Poster Join Date: Sep 2011 Location: In The World Of ALLAH & RASOOL Age: 33
Member: 1647655 Status: Offline Sonork: 100.1640928 Thanks Meter: 50 | Quote:
download ireb MEGAUPLOAD - The leading online storage and file delivery service download 3g 4.1 custom firmware MEGAUPLOAD - The leading online storage and file delivery service run ireb then Open up itunes click shift and give custom firmware and it will restore with out any problem insh***** ) If Incase stuck on sn0wbress logo or apple logo. use redsn0w using original 4.1 firmware and select unthethered MEGAUPLOAD - The leading online storage and file delivery service Once it unthethered open redsn0w and install cydia only then i will not stuck on logo 100% solution Dont forget to press thanks | |
The Following 6 Users Say Thank You to ZJ. For This Useful Post: |
09-12-2011, 18:46 | #5 (permalink) |
Member: 629260 Status: Offline Thanks Meter: 74 | i have tried same to same as you told me .......while restoring custom ispw 4.2.1 itune show error (1015) i had tried number of time but result same error ........and phne restart with pinaple logo and aftr tha a main show is hand rais lol what to doo ? |
09-12-2011, 21:49 | #6 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 707419 Status: Offline Thanks Meter: 6 | Try the following link. It will work. http://forum.gsmhosting.com/vbb/f456...ndows-1132440/ Ignore title as restored this way many times. After doing this you may get emergency calls screen. If you get this open redsn0w, choose stock firmware (not custom) and tick install cydia only and continue Let me know you get on |
The Following User Says Thank You to manutd99 For This Useful Post: |
09-13-2011, 01:25 | #8 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks Meter: 194 | Use tinyumbrella to kick off your device out of recovery mode(error 1015) download from here: The Firmware Umbrella - TinyUmbrella |
09-13-2011, 02:56 | #9 (permalink) |
Junior Member Join Date: May 2010
Member: 1312206 Status: Offline Thanks Meter: 1 | 1. Run itunes. 2. put your iphone in dfu mode. turn off your iphone. when it is already turned off. press power button for 3 seconds. Then without releasing power button press home button for 10 seconds. Then release power button until your itunes shows your iphone is in recovery. 3. press shift at your keyboard and click restore in itunes. select 4.1 firmware for iphone3g. 4. Let itunes do everything and after that error 1015 will shows. Run Tinyumbrella and click exit recovery. |
09-13-2011, 19:12 | #10 (permalink) |
Member: 629260 Status: Offline Thanks Meter: 74 | tried this method but same (error 1015 ) after clik devic out of recovry phond did not come out from recovry mode ....... i alsi tried to update with 4.2.1 but give me same error ever i have chang may pc but same ............. |
09-14-2011, 01:08 | #12 (permalink) |
Member: 629260 Status: Offline Thanks Meter: 74 | restoring whit custm firmware.......while restoring whit custm firmware when its reachd at 90 precnt phone become restart whit pinaple logo and aftr tha apple logo and then a cartoon apear on screen ....whan i perss exit recovery on tinyumbrella phone reboot and then come in same position |
09-14-2011, 22:44 | #13 (permalink) |
Member: 707419 Status: Offline Thanks Meter: 6 | are you restoring in recovery mode or DFU mode. Do in DFU mode (black screen) Try different version of tiny umbrella. Restore snowbreeze 4.1 custom firmware in DFU mode Try exit recovery with tinyumbrella-4.30.05 - as I think i tried higher version and it didnt work but when i tried 4.30.05 it worked. You have to try and get to emergency calls screen. Tried above version a few times so should work. If not you will be something wrong in the process as tried and tested. |
09-14-2011, 23:03 | #14 (permalink) |
Member: 707419 Status: Offline Thanks Meter: 6 | Try creating your own custom firmware through snowbreeze. Try only 4.1 as best firmware for error 1015 is 4.1 iH8sn0w.com |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
