09-21-2014, 18:06 | #3 (permalink) |
Junior Member Join Date: Jan 2013 Location: Algeria
Member: 1875441 Status: Offline Thanks Meter: 0 | hi you can active your iphone 4s and jailbreaking firstly you must know wich operateur r closed then buy RSIM is not expensive then you active iphone with it.....no icloud password....goodluck |
09-22-2014, 02:24 | #5 (permalink) |
Junior Member Join Date: Aug 2014
Member: 2242386 Status: Offline Thanks Meter: 7 | why don't you a buy an R-SIM if your current network is expnsive to unlock? iPhone 4S the sollutions of bypassing are not sloved yet. and if you know your current network buy a SIM and activate it easily. |
09-24-2014, 18:15 | #9 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | If you have an iPhone 4S and Jailbreak always want to have is important that you read this, they are very simple guidelines to make and you will avoid more of a headache ... The iPhone 4S has a security system, introduced by Apple, which forces you every time you update or restore it, to "get" this the newest firmware at all times. It does not matter what version you're on, if you restore or upgrade iTunes will get you the latest version and if you try to force between an old version, iTunes will give an error and will not let us continue. This security is based on a series of Certificates issued Apple, and only Apple, which is linked to the identification of our iPhone 4S with the current version of firmware. It is a single certificate, and Apple only issues certificates of firmware versions then current. For this reason we can only get the newest version of firmware. These certificates are called ECID SHSH-. But for everything there is "cheating" is a way to bypass this security, is to save a copy of these certificates to an external server or in our own pc / mac, so when we want to downgrade what we can do, that's what you do is cheat and instead of iTunes to check for server certificate Apple make on our pc / mac or external server where we put our certificate in his day. Today there is no tool to use certificates in the 4S but it is important to save for when you leave any certificates. The certificate can keep regardless of what version you have installed on the iPhone; eg. We have our iPhone 4S on 5.0 but the current version is 5.0.1 if we keep the certificate at that time, we will obtain the 5.0.1. It is important that you realize that it is more important to go saving certificates as it exits the new firmware, not the failure to gain release. The users think "well, I updated and ready, as I have jailbreak now, I do nothing and nothing will happen to me" and this is wrong, you have to be active and have a safe keeping certificates. |
09-24-2014, 18:18 | #10 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | ON COMPLETION BY APPLE VERSION 6.1.2 OBTAINING SUCH CERTIFICATE BY APPLE SERVER NO LONGER POSSIBLE Back with the crusade to everyone save the ECID SHSH certificate-for the future. In this case we will keep ECID SHSH 6.1.2- |
09-24-2014, 23:38 | #13 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1516047 Status: Offline Sonork: [email protected] Thanks Meter: 0 | restore your iphone then put it in dfu mode then use this tool "iPhone4_Hacktivate_Tool" it by pass activation but cant use the sim card or make any call .... good luck |
