06-08-2014, 17:10 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2189596 Status: Offline Thanks Meter: 1 | how to set imei after baseband replacement? I have an iphone 4 with baseband damage after that chip replacement, my gov wants me to pay 100$ for registration. is there any way to set this imei as same as my old death phone? thanks |
The Following User Says Thank You to secoo140 For This Useful Post: |
06-09-2014, 22:15 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: EGYPT Age: 39
Member: 1298774 Status: Offline Sonork: 100.1584126 Thanks Meter: 94 | iPhone 4 Unlock Dongle (Packaged with 1 cable) + Unlock ID Lock + Change IMEI + Change SN iPhone 4 Unlock Dongle Description: This instrument repairs and helps you to unlock iPhone 4 by changing the serial number, change IMEI, solution ID lock, change the country, change colors, fix 3194 error, 'Your iPhone has problems', 'Need to be replaced', and other failures. Compatible for all iPhone 4 service providers internationally including AT&T, T-Mobile, Vodafone, Movistar, Telcel, etc. NOT compatible for iPhone 4S Model If you wish to unlock, you must have unlock imei and Serial Number. write this to phone then unlock. However you must change the CPU to 8824, and then flash files to 0049 files flash. NOTE: This dongle requires for you to change your iPhone 4 CPU and Flash IC. ------------------------------ Downloadable Files: iMod Factory Tools User manual.exe (5.65 mb) iMod Factory Tools V2.1 OK.exe (55.38 mb) microsoft-net-framework-client-profile.exe (669.63 kb) ----------------- IPHONE 4 UNLOCK DONGLE : Buy iPhone 4 Unlock Dongle (Packaged with 1 cable) - from IPmart.com |
The Following User Says Thank You to MA7MOD_GSM For This Useful Post: |
