Old 09-12-2011, 01:28   #1 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
Arrow how to upgrade 3.1.3 bb 06.15.00
hello
i had upgrade may iphone 3g to 4.2.1 but aftr restart phone was stuck on apple logo ........to get out of this situation i downgrade my iphone to again 3.1.3 but know the bb .upgrated .....phone is work very fine but some of application not suported to ois 3.1.3 ...i want to again upgrade on ois 4.1.0
tell me any one how i can do this .............help me
Old 09-12-2011, 02:48   #2 (permalink)
ZJ.
ZJ.'s Avatar
Member: 1647655
Sonork: 100.1640928
Thanks Meter: 50
Originally Posted by qureshi7 View Post
hello
Qureshi bhai appkay liyah hehe
download ireb MEGAUPLOAD - The leading online storage and file delivery service
download 3g 4.1 custom firmware MEGAUPLOAD - The leading online storage and file delivery service
run ireb then
Open up itunes click shift and give custom firmware and it will restore with out any problem insh***** )
If Incase stuck on sn0wbress logo or apple logo.
use redsn0w using original 4.1 firmware and select unthethered
Once it unthethered open redsn0w and install cydia only then i will not stuck on logo
100% solution
Dont forget to press thanks
The Following 6 Users Say Thank You to ZJ. For This Useful Post:
Old 09-12-2011, 15:18   #3 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
hehe ........... dont knw which one mod i have to use in ireb ?
dfu or get out fix errors ?
Old 09-12-2011, 17:21   #4 (permalink)
Member: 780920
Thanks Meter: 19
1-Put your iphone into DFU
2-Open IREB then click on iphone 3g
3-Restore custom FW 4.2.1
The Following User Says Thank You to c4m3l30ns For This Useful Post:
Old 09-12-2011, 18:46   #5 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
i have tried same to same as you told me .......while restoring custom ispw 4.2.1 itune show error (1015) i had tried number of time but result same error ........and phne restart with pinaple logo and aftr tha a main show is hand rais lol what to doo ?
Old 09-12-2011, 21:49   #6 (permalink)
Member: 707419
Thanks Meter: 6
Try the following link. It will work.
http://forum.gsmhosting.com/vbb/f456...ndows-1132440/
Ignore title as restored this way many times. After doing this you may get emergency calls screen.
If you get this open redsn0w, choose stock firmware (not custom) and tick install cydia only and continue
Let me know you get on
The Following User Says Thank You to manutd99 For This Useful Post:
Old 09-13-2011, 01:13   #7 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
bro baseband is upgrated ..........and after doing all that itune show me error (1015)
any solution.............?
Old 09-13-2011, 01:25   #8 (permalink)
Member: 1488173
Thanks Meter: 194
Use tinyumbrella to kick off your device out of recovery mode(error 1015) download from here: The Firmware Umbrella - TinyUmbrella
Old 09-13-2011, 02:56   #9 (permalink)
Member: 1312206
1. Run itunes.
2. put your iphone in dfu mode.
turn off your iphone.
when it is already turned off. press power button for 3 seconds.
Then without releasing power button press home button for 10 seconds.
Then release power button until your itunes shows your iphone is in recovery.
3. press shift at your keyboard and click restore in itunes. select 4.1 firmware for iphone3g.
4. Let itunes do everything and after that error 1015 will shows. Run Tinyumbrella and click exit recovery.
Old 09-13-2011, 19:12   #10 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
tried this method but same (error 1015 ) after clik devic out of recovry phond did not come out from recovry mode .......
i alsi tried to update with 4.2.1 but give me same error ever i have chang may pc but same .............
Old 09-13-2011, 22:25   #11 (permalink)
Member: 707419
Thanks Meter: 6
Are you restoring stock firmware or custom firmware?
In tiny umbrella did you click on exit recovery? what happened? what is on the screen?
Old 09-14-2011, 01:08   #12 (permalink)
qureshi7's Avatar
Member: 629260
Thanks Meter: 74
restoring whit custm firmware.......while restoring whit custm firmware when its reachd at 90 precnt phone become restart whit pinaple logo and aftr tha apple logo and then a cartoon apear on screen ....whan i perss exit recovery on tinyumbrella phone reboot and then come in same position
Old 09-14-2011, 22:44   #13 (permalink)
Member: 707419
Thanks Meter: 6
are you restoring in recovery mode or DFU mode. Do in DFU mode (black screen)
Try different version of tiny umbrella.
Restore snowbreeze 4.1 custom firmware in DFU mode
Try exit recovery with tinyumbrella-4.30.05 - as I think i tried higher version and it didnt work but when i tried 4.30.05 it worked.
You have to try and get to emergency calls screen. Tried above version a few times so should work. If not you will be something wrong in the process as tried and tested.
Old 09-14-2011, 23:03   #14 (permalink)
Member: 707419
Thanks Meter: 6
Try creating your own custom firmware through snowbreeze. Try only 4.1 as best firmware for error 1015 is 4.1
iH8sn0w.com
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-19-1999 13:12
Page generated in 0.25600 seconds with 10 queries
